Bed Light Install - BdyCM - Error Code B14D8
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
Hi, I’m trying to install the OEM bed lights in my ‘23 Pro. I’ve installed all of the OEM equipment and made the necessary changes in FORscan but keep getting the below error code. Does anyone know what is wrong and/or how to fix? Thanks!
Ford F-150 Lightning Bed Light Install - BdyCM - Error Code B14D8 063DA538-D521-426F-A04A-604484E8444B
Ford F-150 Lightning Bed Light Install - BdyCM - Error Code B14D8 4501D0D0-60E6-40BC-A074-CE96E79C5D7E
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
I'm pretty sure the truck got delivered with this error. Any changes I've made in 'As Built' were reversed.
BennyTheBeaver
Reset the code, power cycle the truck, see if code returns...
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
I loaded default AS BUILT code / power cycled but still no luck
3rdgenfan
Geoff
Delaware
Cybersecurity
I don't recall needing to change anything in the AS Built section of the BdyCM when the bed lights were installed; or did you mean you went through and restored it just to make sure?
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
I made a couple of adjustments based on some coding differences between 22 and 23 but no dice. The code adjustments I reversed once I determined did not work. I restored as built data just be 100% sure.
BennyTheBeaver
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
Yes I reset the DTC code…Now the error is changed to B1616.
Ford F-150 Lightning Bed Light Install - BdyCM - Error Code B14D8 18D2496A-CF9B-44C3-BE11-F8724472F27D
BennyTheBeaver
Well, that (new) fault isn't necessarily tied to the Bed Lights. The first fault could've occurred during the install, before the install was completed. Particularly, if you didn't disconnect the battery prior to working on the electrical system (plugging in the bed lights). Sorry, I'm not more helpful with the new fault code. I'm not sure what that specific code could be.
