Cool mod for VenomRex VR-601 wheels
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
FYI, OEM Ford center caps perfectly fit the centercaps of VenomRex VR601 wheels.
It requires a bit of modification because you have to remove the original backing. I used the heat gun and a plastic trim tool, and the metal FORD plate comes off. Be careful, go slow.
I then used a few layers of double stick automotive tape and it bonds right on. The size is exact. Very pleased with the OEM look of aftermarket lightweight wheels.
Ford F-150 Lightning Cool mod for VenomRex VR-601 wheels 71357005157__A52151B6-C9D4-48CC-A3DE-11BE6B52A80D
Ford F-150 Lightning Cool mod for VenomRex VR-601 wheels 71357006227__40DA07BA-33CC-4119-A653-54EACCE49D49
Ford F-150 Lightning Cool mod for VenomRex VR-601 wheels IMG_7339
Ford F-150 Lightning Cool mod for VenomRex VR-601 wheels IMG_7340
Sparky75
Matt
IA
23 Lariat ER 22 Lariat ER(RAVd) 16 Camaro SS
I have been thinking of Venomrex or Vossens. Can I ask what size rim width did you go with and assume you are using the OEM tires the truck came with?
Looks great and thanks!
csukoh78
Nope
SE USA
20" there is only one width. Stock tires fit perfectly! Saved 13lbs+ per corner. Exact same mileage. Look great
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
I am considering those as well, good to know I can pull the center caps off should I choose to. Thanks for the great idea and information!
csukoh78
Nope
SE USA
You're welcome
csukoh78
Nope
SE USA
Looking at these myself. 0 offset?
12mm I believe. The stats are on the website. Barely noticeable but do look better than stock with a better stance
dustintinsley
Dustin
Salem, CT
I see these wheels come in 0mm offset and +12mm offset. I wonder how much the 0 offset protrude...
csukoh78
Nope
SE USA
I have a 10% increase over 9500 miles with mixed city and highway travel, nearly 50-50. I went from 2.1 to 2.3/2.4.
Losing 48 pounds of unsprung mass and rotational weight does wonders for EV efficiency.
