Powered Subwoofer (JL Audio) fitment
ooSHAZAMoo
NC
22 F150 Lightning Lariat ER
Geek Stuff
ooSHAZAMoo
ooSHAZAMoo
NC
Geek Stuff
Wow...thanks for sharing that post...was looking for something like that. Id Like to go with the 12' of that version, but not sure it would fit. Found this Dual 12' last night so I may try that first. Most of these sites have some sort of satisfaction guarantee so I will start with that then trade up if not happy. at least the wire will be run already.
https://www.sonicelectronix.com/item-200690-Kicker-49PTRTP12.html
BennyTheBeaver
Have a pic of how it looks?
Also a pic of how you connected it to the factory sub/amp?
I have a Pro, 6 speaker system. I connected direct to 12v battery and a Keyloc line level converter. I installed the remote volume control knob in the steering column, near where the traditional key hole would be.
MAG
Ontario,Canada
2023 Lightning Lariat ER,2024 VW ID4 awd Pro S
Hi,I just ordered a Rockville SS10P under seat sub,I want to make sure I hook it up properly to factory sub/amp.I am a little unsure( manual shows high level hook up to both right/left speaker outputs only}.I emailed Rockville to clarify and when they respond I will let you know what they say.
rsanapala
Rakesh
Dallas,Texas
2023 F150 Lightning XLT
I installed this in my SUV. Got the inputs from the front 2 speakers and connected them to sub’s high level inputs and it worked fine. Don’t need a remote input. It worked well for me as I was looking for more mids.
Jdella31
Josh
2023 ER Lariat
Construction Manager
ooSHAZAMoo
ooSHAZAMoo
NC
Geek Stuff
Did a LOT of searching around and went with this.
Be sure to get that LC2i Pro LOC (do not go with cheaper one). Also get a bass knob. You will need it becuase some songs it will be too much bass.
Kicker TL7T Single Square 600 Watt RMS 12 Inch 2 Ohm Solo Baric Subwoofer with Thin Enclosure and Big Bass for Car Audio Stereo Systems, Black
Ford F-150 Lightning Powered Subwoofer (JL Audio) fitment 1710412120533-lm
ooSHAZAMoo
ooSHAZAMoo
NC
Geek Stuff
Oh...i did have the under seat storage but I removed it, so now there are 4 bolts sticking up, but not a big deal. The pic above is not my photo but a review from amazon...you can see the bolts sticking up there.
