Longhorngary
- Mar 7, 2021
- Austin, Texas
- 2017 Ford F150 302A soon to be 2021 F150 KR PB
Installed my new Revolver X4s truck cover on my Smoked Quartz King Ranch. I had a Revolver x2 on my previous 2017 XLT which I liked but it had a couple of flaws both of which have been addressed in the X4s.
I like the Revolver covers as they seem provide a little better security a typical tonneau cover. Constructed of aluminum allows an evenly distributed 300lbs on top of the cover when closed. I enjoy that when it's rolled up against the cab it doesn't block your entire view out the back window like most bakflip type covers.
The two problems I had with the original version centered around the heavy felt used on the backside of the cover that you used to roll up the cover. After a few hot summers in the Texas sun, the adhesive on the felt backing gave way and the felt came off of the cover. While Bak Industries had a replacement kit, based on reviews this adhesive also failed.
On the new X4s, they have ditched the felt and gone with a more rubberized material that seems to be attached much better than the original felt. Only time will tell how the new backing holds up, but at first blush this seems like a marked improvement.
The second problem with the original cover was the strap latches used to secure the rolled up cover at the front of the bed. These were typical plastic male/female buckle claps that proved awkward latching against the rolled cover. Bak has ditched the traditional buckles and gone with a T shape handle that's inserted into a slot and rotated 90 degress to lock it in. This seems much easier and more secure. Again nice improvement.
Last not really a failing of the original model, but a convenient improvement on the design are the plastic hand knobs rather the original metal nuts. This means the rollable cover can now be removed quickly and easily without the need for any tools.
So far I'm very happy with my purchase. Well done Bak/Truck Hero
Here are some pics.
Here are some pics.
