What is this secret door?
Adventureboy
Isn’t one of those little cubbies for when you have to reprogram the key? I helped a coworker on an older F150 when he suddenly couldnt turn on his truck. We had to look all over for the hidden spot, but you basically put the key in there, follow a few steps, and it matches the key to the truck.
If you have two working keyfobs, you can program a third with a dance sequence. I don't think you can program a key using this port without two working keys without taking it to a dealer.
Marcelo Zanetti
Marcelo
New York
Ford F150; Ford F-150 Lightning; Ford Explorer;
No, see post #10.
Why go to all this trouble if you can program your phone-as-key (PAK) and create a passcode for when the key is not detected in the vehicle?
I've done that and used it a couple of times...
Trouble? Not following.
You go to use PaaK and it doesn't work. Try to use passcode, and no keyboard appears. You try your fob, but the battery died. So... you put the fob here and it works.
Or, you buy a 3rd fob to program and store, so if one is lost you don't have to pay the dealer to do it. Need it for that.
Marcelo Zanetti
Marcelo
New York
Oh, okay... I see your point now.
invertedspear
AZ, USA
lightningcalcs.pages.dev
Further PAAK is only for Lariats and Platinums. Different dashboard form the XLT and Pro, but same center console.
Marcelo Zanetti
Marcelo
New York
I see! But if I understood correctly, the receptacle under the cup mat will make the truck work with a dead fob key, right?
invertedspear
AZ, USA
It's supposed to, yes, can't confirm, I've yet to need to test that :)
