Wheel Offsets - I Need Help Understanding / Fact Checking
SNBI18
NJ
24 Lariat
I being told the OEM offset of the lighting is +40. The wheel I had picked out was a 0 offset. I was told a 0 would push the wheel out 2 in. And that I should search for nothing more aggressive than a +20 since I'm not doing a level or a lift.
Can anyone confirm that this information is correct when I'm being told.
I had one shop tell me the zero will push out my wheel about an inch and another shop tell me it'll push it out 2 in with drivability issues.
potato
BC, Canada
2023 F150 Lightning XLT ER
If it's the exact same width of wheel and tire, then a 0 offset would have the outside edge 40 mm farther out than stock, or 1.575".
If it's a wider wheel/tire, then 0 offset would push the outside edge out further. Could be 2". If it's a narrower wheel/tire, then 0 offset would push it out less. Could be 1". So the two shops could both have been giving you more or less correct information if they were talking about a specific wheel/tire combo that was a different width.
SNBI18
NJ
24 Lariat
My goal is for appearance before functionality. I wanted some extra poke, a stylish tire that was quiet on the road as much as a AT can be. I was planning on a 285/70/18. OEM is 275/60/20. I was going at a 18x9. The wheels I loved are 0 offset. Other wheels that are just ok are from +10,+18 and +20. I don't want to level or lift it.
WildBlue
Somewhere
2024 F150 Lightning Flash
The offset of the Lightning 20" wheels is +44mm, not +40mm.
SNBI18
NJ
24 Lariat
So would a 285/70/18 on a 18x9 +10 off set with no level be an issue?
Itaintfastenough
Woody
Grandview Texas
2020 Transit Connect, 2023 Lightning Pro ER
HVAC Contractor
The offset on my Pro with the 18” wheels
Ford F-150 Lightning Wheel Offsets - I Need Help Understanding / Fact Checking IMG_8662
Itaintfastenough
Woody
Grandview Texas
HVAC Contractor
I am also looking for wheels, but few available with that off set @ 18”
mb0220
Matt
2022 Lariat ER
I upgraded my wheels to a 20x9 with +20 offset, and tires are 285/60r20. There is a slight poke (would have preferred none), but not enough too make me dislike it. As far as fitment it seems to be fine - haven't noticed any rubbing, but it is definitely CLOSE in that front wheel well, especially at a full steer.
SNBI18
NJ
24 Lariat
I went with a +10 offset, and dropped the 285 for a 275/70/18. If I wanted the 285 I would have had to drop the 70, but then with the 18's the truck would have sat lower. Hopefully getting it all done Wednesday.
