Do you have all the camera views showing on the left side of the 360 view ?
I'm in a similar situation. Truck came back with tiny 360, I used FORScan to bump it up. Are you asking about the menu button? I still have that.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
I fixed mine with FORScan also but lost the menu button. I seem to permanently have all the icons to switch camera views on the left side of the 360 view, like @Dinozero.
Mine definitely still requires the menu button to see the camera modes. Well, my mongoose is supposed to arrive today. Guess it's time to brush up on FDRS. Anyone know if I have to get a license to run that configuration tool? I hadn't planned on getting it just yet. Don't have the time to knock out the big updates and make it worth my time/money.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
24 flash purchased 9/3/24. where do I find what version of BC I have?
Rick
Fast87t
Gary
Ohio
2022 F150 Lightning Lariat
+1 How via forscan? I had both CSP's done last week
I have different camera views on the left side of my screen after I changed to a bigger vertical camera view in forscan. I want to know how to get the BC 1.4 going that you did in forscan.
It definitely did not make your current blue cruise smoother or any different. Unfortunately you're experiencing confirmation bias. Kind of like when a teenager puts a bottle octane booster in their gas tank and is convinced he can feel a 20hp gain in power ?
Well, not necessarily in this case. That update does update the software on one of the modules directly responsible for BC performance. As a matter of fact, the original version of this update (6.13.0) completely broke BC for many people, hence the name of the update "CMR-FX". it is very possible that the improved BC performance he noticed is not a placebo.
Pretty strange that we have different behavior for what should be the same fix.
Hmmmm...now you have me second guessing myself. I'll have to go out to the parking lot at lunch and double check.
I had the TSB for the front parking sensors and battery done….then bluecruise worked much better….looked into it and was able to enable it via forscan and now have 1.4….it is amazing, even with level and bigger tires it is nearly flawless and the lane changing works way better than expected…I actually prefer this on the highway to my model s autopilot
What did you change with Forscan?
After the parking sensor CSP I noticed I get a message that says BlueCruise is available when I merge onto a highway. It was more aggressive at lane centering and made it around two corners I always had to take over before the update. It would not change lanes with the turn signal, however.
Help me Jersey Mike, you're our only hope!
JerseyMike
Allentown, NJ
2022 Ford Lightning Lariat SR, 2" pucks, P275/65/20 Nitto Recon
Sounds like mine after the CSP (it no longer made me takeover on 2 highway turns that it did in the past)>
anyhow another member on here shared some forscan changes. I’ll dig them up and PM you (just make sure you backup or copy down your current codes in case they don’t work)
@Warp Asylum I double checked and I still have the menu button after using FORScan to fix the tiny 360 view. Did you do anything other than change that one character? I've got my mongoose now, I'm beginning to think I'll need to run the config tool once I'm ready to buy an FDRS license.
Warp Asylum
Austin, TX
Nope, I just changed the one character from 2 to 3 per the instructions.
I would prefer the menu button to be honest, the camera view was a little larger than with all the icons to select different views.
ryry
Ryan
Nashville
Lightning Lariat ER
Could you PM the forscan changes as well?
