Ipma not loading on forscan
theUNSTABLE
Ryan
github.com
Cyber Engineer
BC with lane change and centering
Is this implying you added Blue Cruise with land change and centering through Forscan? Do you have the hardware for BC?
I don't have the hardware so I never looked twice at the various threads talking about BC but now you have my thinking...
Edit:
I also had this ipma fail to load issue trying to enable Matrix style last night. I got around it as @VTbuckeye said with "using the not "as built" module option" option (English option, easy option, etc)
Although I feel like I may be going crazy because I think the backup camera guidelines are gone now and I could have sworn those were there before.
All I've done is:
- Matrix Style High Beams
- Initial start no seatbelt chime delete (European style as someone said in the giant thread)
- Rain sensing wiper add (but doesn't work due to hardware power)
I did some APIM / IPMA programming (BC 1.2 related) two days ago with version 2.3.63. The only issue was when starting the IPMA As-Built configuration, I got a brief message with some beeps on my instrument cluster:
Ford F-150 Lightning Ipma not loading on forscan 1733188401950-vl
But I was able to change and write data. I use the OBDLink-EX adapter.
For 2022 and 2023 BC and associated hardware is included with Lariat 511A (aka the ER battery) but not with 510A (SR battery). He has the ER based on his profile.
Edit: He didn't add BC, but updated it from 1.0 to 1.2+
ashadkc9
Kansas City
Yeah, I should have clarified. I had 1.0 from the factory, and have all the modules updated via OTA or dealer and through CSPs. I just changed the few config items via Forscan to take my BC 1.0 to 1.2 (or 1.3 or whatever the number is). I don't have the animations for the lane change or anything, but the functionality works.
Ynnhojnorood
NC
‘23 CR1 Vapor Blue, ‘23 Lariat ER Rapid Red
I got this to work on my ‘23 Lariat. I am on 10.1.1 and I just picked it up from the dealer who installed some updates and performed some recalls. The same message “normal cruise active…” popped up a few times for me. The sliders show up and work. It doesn’t look the same as the MME, but it seemed to change lanes better than BC 1.3 on the MME. I didn’t see any improvement on slowing through turns, so I think a few things are still missing or not up to date.
MilkMan
F150 Powerboost
Update: It was my ELM 327 OBDII adapter. I needed to tell Forscan to auto increase the Baud Rate. They also gave me the .64 test build, so between those two things I now have Glare Free and BC with lane change and centering.
I know this thread is old, but for anyone else that finds it in the future like me, checking the box "Auto-increase" under baud rate allowed me to run the IPMA module. Forscan did warn me upon opening that my ELM327 OBDII was not fully supported which I assume may be related? Either way, thanks!
