OEM Kicker Subwoofer
sstevetx
Steve
I can't see how it wouldn't be an upgrade from the factory sub which is a 6x9 in a small, ported enclosure. The port is accomplished with a hole in the rear cab, so you have to plug that. I included a couple of links for reference.
Pic of stock B&O 6x9 subwoofer disassembled
https://www.f150forum.com/f129/option-replacing-factory-subwoofer-528196/
Pics of all lightning B&O 8 speakers along with a full, diy upgrade (not cheap)
Low / Medium Cost Audio upgrade | Ford Lightning Forum For F-150 Lightning EV Pickup: News, Owners, Discussions, Community (f150lightningforum.com)
Potential 6.5" subwoofer swap from Maverick forum. Not sure if this makes a big difference or not, but the Maverick owner who posted it was happy with it.
https://www.mavericktruckclub.com/forum/threads/simple-b-o-upgrade-and-sub-solution.38884/
VictorM
VictorM
Victor
Western PA
F150 Lightning XLT ER
Experiential Knowledge Griot
Tkageals
Todd
VA
2023 F-150 Lightning XLT
I just had this done in my '23 XLT. Now I have low phone volume issues. Everything else seems fine, but I am having to max out the volume when on a phone call. Any ideas?
VictorM
VictorM
Victor
Western PA
I’m having the same issue and plan to research Forscan settings for a solution.
Tkageals
Todd
VA
I wonder if the installation instructions are available. Maybe there was programming information in there?
Tkageals
Todd
VA
Thanks for the install instructions. I can't address the software myself, but I did email the tech support link provided in the documentation. We'll see if I get a response.
Redbaron
Robert
it was worth it. The wiring was there and no additional controls are added To the screen. The sound is significantly better just by adding the sub. my Next step is to check Forscan for any changes i can make in the Audio Control Module ( ACM) for the upgrade. You can save $200 if you install yourself.
did you ever get into forscan? I’m trying to configure my kicker subwoofer and I’m struggling…. I can’t get it to work
Redbaron
Robert
I picked up the ford accessories kicker subwoofer for cheap and had questions regarding the forscan values. It appears the default values for the acm are different than the ICE f150.
Changing the values in the 727-01-01-xxx* didn’t activate the subwoofer.
Does anybody have any experience changing the ACM values for this truck?
If anybody has enabled the subwoofer from the dealer what values does forscan show now?
Any help is appreciated. Starting to get worried that I wasted my money.
B177y
Olympic Peninsula, WA
B177y
Redbaron
Robert
Redbaron
Robert
I don’t have FDRS.
There are many posts with people successfully installing the kicker with an ICE-150 using forscan.
It appears that that ACM values may be different in the lightning compared to the ICE.
B177y
usually you can use either. I believe FDRS just changes values that forscan changes.
People with ICE f-150 use forscan to install this subwoofer commonly.
I was hoping someone that had the FDRS done by the dealer could read the forscan values for me.
Possibly... But the first FDRS instruction is "Download ACM - Sound System Upgrade"... I don't think that is available in ForScan.
There is also an ACM PMI step (Programmable Module Installation).
In my very limited experience using both FDRS and ForScan, FDRS seems to get much "deeper" into the programming (I don't know what other words to describe it).
B177y
If you only have Forscan, try poking around the Lightning Forscan spreadsheet by @Livnitup :
