GoHawks
I recently completed an audio upgrade which I started over the summer. After a lot of research on this forum, the other Lightning forum, and Youtube I pulled the trigger. I did not upgrade the head unit for obvious reasons. I am adding this content because most audio upgrades on this forum are multiple thousands of dollars. I am not an audiophile, and listen primarily to Sirius/XM / Apple Music / Spotify. Total cost was under $1000 (more likely $850 but I didn’t track all of my receipts). I was initially hesitant with such expensive truck but found the job to be easier than I thought (with help listed below). I was slow and careful. BTW the B&O 8 speaker system is complete garbage.
This has made a HUGE difference. It is so much better.
A couple of clarifications : 1) I have never worked on car audio before 2) I am a strong believer in YouTube university 3) I am pretty handy 4) I have had to figure out a lot of electrical gremlins in boats so I was not too worried about doing this.
I want to shout out soundgoodstereo for the plug and play sub adapter, sub block plate, and front/rear door block out plates.
I also want to shout out provobeast on YouTube () for a complete walk through of front/tweeter/rear speaker tutorials.
I had to figure out the sub replacement and center dash speaker on my own. The trickiest parts were running power to the 12 V battery from the rear seat area for the sub and replacing the A pillar tweeters. I broke a few clips when removing certain trim pieces along the way. The tweeter factory wires were extremely small and hard to join with the speaker wires. There is no aftermarket harness for them. The 4 door speakers and sub have adapters (links provided). I also had to ‘hard wire’ the center dash speaker.
I ended up running wiring under the drivers side door channels for the sub control and power. I poked through the ‘firewall’ under the drivers side steering console. There is a rubber grommet that allowed me to route to the 12 V battery. (I have had not 12 V issues at all). I strongly recommend buying a good trim kit instead of using pliers and screwdrivers.
Here is a list of parts. Most came at the recommendation of provobeast. Sound Good Stereo has a lot of great options as well, but those were out of my price range. The sub fits perfectly in the existing spot and is only attached with command hook Velcro.
https://soundsgoodstereo.com/produc...ck-off-plate-for-rear-wall-includes-unleashed
https://soundsgoodstereo.com/products/2021-2022-ford-f-150-custom-made-door-access-block-off-plates
https://www.amazon.com/KICKER-46HS10-Compact-Powered-Subwoofer/dp/B083M9HR4D
https://www.amazon.com/Alpine-R-S69C-2-6x9-inch-Component-Speaker/dp/B07ND4GY3Y
https://www.amazon.com/Alpine-R-S65-2-2-inch-Coaxial-Speakers/dp/B07N135NBY
https://www.amazon.com/Infinity-Kappa-Perfect-300m-Midrange/dp/B06XNLBL7Y (dash speaker - I have an extra if someone wants to make it worth my while to send it their way)
https://www.amazon.com/Speaker-Harness-Compatible-2010-Up-Vehicles/dp/B09BDKHPHF
https://www.amazon.com/Metra-72-5602-Speaker-Connector-Vehicles/dp/B016YIFQ7I
https://www.amazon.com/Metra-825606-Front-Speaker-Plate/dp/B01BTSVYGK
https://www.amazon.com/Metra-825605-Rear-Speaker-Plate/dp/B01BTSVXWK
https://www.amazon.com/GOOACC-Retainer-Fastener-Terminal-Adhesive/dp/B0BLCDRDY6
https://www.amazon.com/ELECFUN-10-22AWG-Connectors-Insulated-Electrical/dp/B07G5W9PH1
