Adding power mirrors to XLT
Ahmram
Ahmad
F150 Lightning XLT
just finished my install up with the boostedbygreygoose harness. Everything was easy but now my 360 camera is just a blue screen, the backup camera is the only one showing. Anyone else run into this?
I believe someone on this thread faced the same issue and had to replace the cameras from the original mirrors. That's what I did with mine and didn't face any issues.
Froman
Austin
2023 XLT ER
OK, just replaced the camera plate with camera and led light on the driver side only, fixed for all cameras now. so strange. I attached what it used to look like, but changing just the driver camera seemed to resolve it.
Ford F-150 Lightning Adding power mirrors to XLT thumbnail_IMG_6587
pookguy88
cars
So I saw this thread and also a similar one in the F150Gen14 forum and started looking for some power fold mirrors on ebay, etc. I happened to find a guy selling take offs from an ICE F150 Lariat which were the same color as my truck (Carbonized Grey). Bought those, the boosted grey goose harness and a new door switch (ML3Z-14529-CC). The mirror and harness install are very straight forward. Everything is working, 360 cams, BLIS, puddles, etc. Here are the part numbers of the mirrors. The drivers side is also dimming but I chose not to wire that up as I have heard some people don't like it and I really don't need it.
did you have to replace the camera(s) in the mirrors with your original camera?
derelict
XLT ER
No, the ones that came with the mirrors I bought worked fine. I know some have had issues and had to swap their cameras in but that didn’t happen to me.
pookguy88
cars
great thank you, good to know the cameras in a new set of mirrors are supposed to work
did you buy the new power window/mirror control panel for the door too? And for the harness, did you have to take off your door panel(s)?
I'm really wanting to do this mod so just trying to wrap my head around it
derelict
XLT ER
The best resource I found for doing this is in this thread, I recommend you read all of it:
https://www.f150gen14.com/forum/threads/xlt-power-folding-mirrors-retrofit-how-to.10718/
Here are some highlights (going by memory):
Mirrors - Best if you can find takeoffs from a Gen 14 Lariat or a Lightning with the same color caps. Otherwise you will have to swap/paint the ones you get. I found a guy selling mirrors the same color as mine so it was easy.
Wiring Harness - At first I had heartburn paying for the boostedgreygoose harness and wanted to do it myself. But trying to figure out exactly which pins to buy was a pain and at the end of the day I figured it was tried and true so I just bought the harness. You need to fully remove the door panel to install this (on both sides) but it is not hard. There is a guy who made a youtube video doing this
Door switch - You have to replace the door switch with the one that has the power fold button: ML3Z-14529-CC. I got mine on ebay for $36. You do not need the bezel that holds it, you can unscrew the stock switch assembly and this is a drop in for that space.
Forscan - You will need Forscan to make the proper changes for the mirrors to fold and to get the options for the mirrors to show up in the menu
Overall it is not difficult and if you read up on everything first, then take your time and everything will be fine. I say go for it and good luck!
pookguy88
cars
thanks, appreciate the insights, now to find some mirrors
21st Century Truck
Martin
FYI - switching outside mirror caps is very easy. You pull off the mirror glass with an angled trim tool and then unscrew three plainly visible Torx screws, and swap the caps, and then reassemble.
pookguy88
cars
yeah I'm reading/watching up on it now, after doing all this looking around, it seems like only color-keyed mirrors have the power folding option in them. The plain black plastic ones don't have power folding so I might want to go stealth and just put my plastic cap on one of these colored ones
21st Century Truck
Martin
That's exactly my path as well. Frankly, I like the black plastic mirror caps... much less ding-prone.
Moe
F150 lightning xlt ER 23
Anyone try the chrome colored mirrors ? Found some locally off of a 21 lariat. Chrome cap with all options. Pf, blis, cam, etc. My driver side mirror is destroyed so I don't have the options of swapping camera module over.
fvineyard
Frank
Roanoke, Virginia, US
2024 F150 Lightning Flash, 2023 IONIQ 5 SEL
IT Manager
I think that should work. As long as they are not model year 2024 mirrors I think they should work. 24 mirrors on a 23 truck is the only mention of the cameras not working that I have read about. I am not an expert, but I did scour the internet on this topic and there are maybe two references to that particular combination not working that I have found.
Moe
Oh I see I might have missed that pattern on the cameras being from a 24 and installed in a 23. I just was not sure if there is a particular set of mirrors from the years 21 to 23 that I should be looking for. The only variation I could find is that some power folding mirrors are paint matched and some have the Chrome covers but they all have the same features as far as 360 cameras blind spot heat and puddle lights
