'22 Pro Alignment/Steering issues
NoCharge
Midwest
'22 Lighting Pro Iconic Silver
Just under 12k miles and have been battling since new. First alignment done under warranty (3k miles)the rear was adjusted as the steering wheel was off center from new. Not sure if it was toe, camber etc. or even which side. Drove better and the wheel seemed straighter but not perfect. As I drove it more, something just did not feel right. At round 6,500 miles I took it back in. This time it was discovered the the steering wheel was put on wrong at the factory. I saw it with my own eyes. The alignment rack was all in the green and the wheel was almost 180 off. The front tie rod ends were offset to one side. When compared to another Lightning, you could only turn the wheel one way maybe 30 degrees under "pitch & roll" and maybe 38 degrees the other way. The other Lightning was 34 both ways. Removed the steering wheel, installed it back to correct position, re-aligned it and it was light years better, but still not right. Fast forward to now. Religned again, now both sides of the rear were out of spec. I sat in the truck and held the wheel dead straight as they re-aligned it. All indicators on the alignment were green and matching. Drove it and the steering wheel still resets to the right and if you hold it dead straight the truck drifts left. They have also reset the steering module.
Is anyone else had any issues?
dlat48
2022 F150 Lightning Lariat
Not this exact issue but I did have issues after about 25k miles on my steering sticking when on or off blue cruise. It wouldn't come back to center then all of a sudden let lose and come back to center. Very dangerous. After 3 attempts at finding the issue I was told I needed a new steering rack. Being put on this weekend.
They did some of the same module resets you are speaking of but it did nothing. I'm hopeful the new steering rack will fix it.
NoCharge
Midwest
Good luck. Mine is still not right and am down to my last 1000 miles on warranty. They put yet another rack and an intermediate shaft in it and it’s still the same if even worse. Now it just straight pulls left and they can’t get aligned on top of the original issue. I’m not sure if it’s mechanical or a software issue but I’m beyond pissed at this point.
broncoaz
Cape Cod, MA
If you don’t have an extended warranty you probably should invest, seems like it will pay for itself. Also this really sounds like a lemon law buyback issue at this point.
rdr854
Northern Virginia
I may have the same problem on mine. Fortunately, I have an extended service plan from Ford.
