Dimensions of the rear part of the frame.
vaiker
Tomek
F150 Lightning Lariat 2023
I have a lightning after a small collision, can someone measure the dimensions between these points for me? Or is there some document with these dimensions?
Ford F-150 Lightning Dimensions of the rear part of the frame. rear
Ford F-150 Lightning Dimensions of the rear part of the frame. u
You don't say what got damaged - it looks like the right side rear of truck.
In your bottom photo, the two lines should be equal. Looks like the bottom left frame is bent at the very rear. So the line that goes top left to bottom right should be "good".
I would think again, assuming the damage is on the right side rear of truck, you can measure height on the left as "good".
Ford F-150 Lightning Dimensions of the rear part of the frame. 1738086123711-sv
vaiker
Tomek
I need to fix the right rear frame of my car
Ford F-150 Lightning Dimensions of the rear part of the frame. Zrzut ekranu 2025-01-28 184409
MaintGrl
Marsha
El Sobrante, Ca
Well, not seeing it in person, I would venture to say that both segments should be identical . . .
jweggy
Joshua
2024 Ford F150 Lightning Lariat 2021 Ford Mustang MACH E GT performance edition
@vaiker I have an unrelated question for you please. Does this truck you have apart here have the the 240V,7.2kW inverter that comprises the "Pro Power Onboard 9.6kW" factory installed option? If yes, can I please see some detailed pictured of the 7.2kw inverter and its associated connections? if not , does it look like the factory harness has unused connections that could potentially allow for this to be retrofitted? I am trying to determine if it is possible to retrofit the 7.2kw inverter into a lightning that does NOT have it from the factory.
HOTAS
Airbus Pilot
His is certainly Pro Power 9.6.
I can see the big 7.2 inverter right there.
