Want to level... to raise or to lower?
Mcfly
Billy
Socal
23 Pro SR
Realtor
Op please post pics once you install the kit. I did the rear, lowered 1.5 inches. But I still have a 2 inch rake compared to the front. I also have the parts for 2 inch and 1 inch front level but can't decide if I which one I want to install.
Tractionlimit
Tractionlimit
Ryan
2024 F150 Lightning Flash
Exactly. Someone needs to make a 1.25" or 1.5" front spacer for this thing!
I haven't gotten around to installing mine yet, but hopefully will in the next few weeks. I'm now leaning toward trying the + 3/4" front first with the rear -1.5 drop. Then go to 2" if it's not enough. If I were definitely going with bigger tires, I'd do it the other way, but staying with stock size for now.
Tractionlimit
Tractionlimit
Ryan
Here's the 3/4" Rough Country kit installed, front and rear. Overall fairly mild, but clearly better than stock. Open tailgate is at least 2" lower, so that's a plus for loading.
It left me with about 6.25" fender gap in front and 7.00" in the rear. I'd rather have zero rake, but the 2" front lift /-1.5" rear drop would have given more negative rake than this is positive.
Ford F-150 Lightning Want to level... to raise or to lower? 20250131_165651
Ford F-150 Lightning Want to level... to raise or to lower? 20250131_165702
Ford F-150 Lightning Want to level... to raise or to lower? 20250131_165715
Mcfly
Billy
Socal
23 Pro SR
Realtor
Looks great! I'm going with bigger tires 275/65/R20 so I'm leaning towards installing the 2 inch front spacer. My rear kit didn't lower as much as yours did. I used shock mounts ment to lower the ice trucks, this was before rough country released their kit. Your truck looks awesome. Thanks for posting the pics.
Tractionlimit
Tractionlimit
Ryan
Thanks. Yes, I like that tire size too. I'm fairly certain 275/65R20s would fit mine with stock-offset wheels, but would not fit with my +6. Maybe there's an offset in-between that could fit. Really only worried about the front air dam lip, which I know some have trimmed.
digitaldad
ABQ
2023 Lariat ER MaxTow
How has the ride quality changed, if at all?
Tractionlimit
Tractionlimit
Ryan
I've only driven it 10 miles around town, but no noticeable difference, nor did I expect there would be.
Only noticeable change was the headlight angle, so I aimed them 2" downward, which was simple.
digitaldad
ABQ
Good to know, thanks. In reading, you do not need camber adjustment for this slight lowering in the rear. I'd really like to go lower but this seems an ecomomical compromise to at least getting rid of rake (and not lifting, as in lifting vs. lowering). If you did an alignment, was there toe need only?
Tractionlimit
Tractionlimit
Ryan
I did the full alignment, but as you noted, rear had no adjustment.
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
Now that I assume you've driven more than 10 miles any further comments on ride quality?
I'd really like to do this as well but concerned about ride quality as my last Rough Country install on a gas F-150 made it way worse.
Tractionlimit
Tractionlimit
Ryan
I'd still say no difference in ride quality. I noticed more of a handling change when I installed winter tires on 6mm offset wheels. The lightning does float around a bit more than I'd prefer, but it did that from day one, stock. What did you experience previously?
mattskr
Matt
Austin, Texas
That's good to hear. I don't plan on changing tires.
I had a 2018 F150 and put on the 6" RC Lift. It was significant change in ride quality. I was able to fix the front by purchasing some aftermarket adjustable coilovers but I was never able to fix the rear and people riding in the back seat complained.
