Lightning Tremor Build
norcalitguy
James
2024 Ford Lightning XLT SR
My truck has been thru a few different builds. It started out as a stock pro, then modded into a budget Lariat. Because of the standard battery pack I was hesitant to do an off road build but I finally caved in. I've always liked the way the Tremor Ice trucks look and thought Ford should build this trim. Who knows maybe they will, a test mule was seen driving around a few years ago. I got the inspiration from seeing a post on the Raptor skid plate. Shout out to @Electric Marine and @AZT9. From there I just started getting the parts together. As for efficency, its been better than expected. I'm at 1500 miles on this set up, averaging 2.1. But that has included some road trips with an IKamper over the bed and a dirtbike on a hitch carrier. On my daily commute I average 2.3, 32 miles round trip mixed freeway (65 mph) and city.
Parts
Raptor Skid plate used ebay, I used a similar method to @derelict and what @Electric Marine and @AZT9 did for trimming. Active aero removed and disabled using Forscan.
Tremor lower valance trim Pieces, ordered from the dealer, part numbers ML3Z-17626-DA and ML3Z-17626-AB. The tremor skid plate is narrower than the raptor so you will have to trim these a bit. They sit on either side of the skid plate, bolt up with the existing holes under the bumper.
OEM Bedside and tailgate tremor decals ebay, removing the adhesive left from the lightning badges was harder than expected.
Raptor running boards used offer up, these suprisingly mounted up to the mounting brackets no problem. I found a set missing the brackets for sale locally, I just unscrewed my running boards from the brackets. I installed a set of led lights under the rear fender to replace the lights that were on the stock boards.
Upfitter Switches, link to my install thread https://www.f150lightningforum.com/...fitter-aux-switches-how-to.25671/#post-492493
Towhook covers, Steering wheel decal, Grill decal, etsy. I wanted to mimic the 2024 style Ice tremor grill. I found a seller on etsy to make it custom. The towhook covers and steering wheel decal were listed for sale.
2 inch front Leveling kit, Rough country, this combined with the 1.5 inch rear lowering kit gave the truck a .5 inch rake.
1.5 Inch Rear Lowering Kit, I used the ice McGaughy's shock mount lowering kit and Icon rear camber kit. Rough country also makes a rear shock lowering kit now. I'm glad I installed the rear camber kit. I was able to do a 4 wheel allignment after getting the wheels and tires.
Trex T200 Wheels, Forged Monoblock 6061-T6 Construction, rated for 2456 lbs each, weight around 28 lbs.
Nitto Recongrappler AT Tires, size 275/65/R20 (34), 116t load rating, weight 47 lbs.
Did you install the lydar?
abcut973
Anthony
Denham Springs
Definitely a nice build ?? . I wouldn't use the tremor decal though. How many angry looks do you get from tremor owners? Lol
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Thanks! No angry looks yet, not that I would care. Where I live in socal Tremors are a pretty rare sight. I spot 20 raptors to 1 tremor. Next time I see one I'll make sure to pull up next to them so they can get a good look. ?
boardriderb
2024 F-150 Lightning Flash
What module and setting did you change in FORScan to disable the active air dam? Does this prevent it from throwing a code?
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
I believe it was this, @Jesse-Infotainment would be able to confirm. And yes this will prevent the truck from thowing codes. But if you don't make the change there is no notification on the dash that the active aero isn't working. My truck is a 2023.
Corrected
7E0-162-02 XXXX XXXX 01xx
boardriderb
7E0-162-02 XXXX XXXX 00xx
Thank you! Which module is that under?
Jesse-Infotainment
2024 F150 Lightning Platinum
Its in the PCM.
THis is correct
It would be a 4 and changing it to a 1 would turn it off
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Looks great bro! I've started down the Tremor Road. Not there yet. Have to figure out the front grill situation...
Looks great! You have my fav color for a Tremor. The orange really pops on Antimatter Blue. Let me know what you come up with for the grill.
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
I found some ICE oem take off Tremor seat covers on Ebay, just finnished the install. I also have a take off steering wheel coming and the center console cover. In the meantime heres the seats.
Ford F-150 Lightning Lightning Tremor Build IMG_20251029_153849953
Ford F-150 Lightning Lightning Tremor Build IMG_20251029_153959528
Ford F-150 Lightning Lightning Tremor Build IMG_20251029_153910881
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Tremor steering wheel and center console cover installed.
Ford F-150 Lightning Lightning Tremor Build IMG_20251106_143043498
Ford F-150 Lightning Lightning Tremor Build IMG_20251106_143046164
Ford F-150 Lightning Lightning Tremor Build IMG_20251106_143038537
jsilvia
Josh
2024 Ford F150 Lightning XLT
Just to clarify, you fit OEM non-lightning seat covers on your lightning? I ask because I’ve been trying to find some I like and the seller says they won’t fit my Lightning because the seats are different than the reg F-150. I disagreed but he even insisted he got returns from lightning owners because they didn’t fit right.
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Yes they are non lightning oem covers on my oem pro lightning seats. Lots of people have swapped for the non lightning leather Lariat seat covers as well. I think as long as your not trying to put platinum covers or raptor covers on they should fit. The raptor trucks have additional bolstering.
Pod
2023 AMB Lightning XLT SR
How difficult was the seat cover install? Looks so good. I’m not sure im smart enough to install those correctly.
