2024 FLASH with Tow Technology (Brake Controller)
Wildneg
Kevin
2024 FORD LIGHTNING FLASH
Solution Architect
So I've been researching and it's a mix bad of information.
I'm looking for exact part I need to get built in in functionality on the truck and the gain control, where the coin slot is.
I saw part ML3Z19H332AA mentioned. But the. I see ML3Z19H332AB. Is it correct AB is the one? I read both work but AB is just the newer version and replaces AA.
This comes with the controller module and the gain slide/control, correct? Sound like my truck has a controller but YOU HAVE TO REPLACE the one there with this module and then hook up the gain control. Alot of reading, this is what I e concluded.
So if all that is correct, I'll need to then do some updates with ForScan. I have not tracked those specific changes yet, but sound like once that is updated, everything becomes available, correct?
Just wanted to verify so I order the right thing and have it all ready. Have to take the riding mower in and tractor for yearly maintenance.
Thanks in advanced!
mxracer
Dan
2024 F-150 Lightning Flash
Having just gone thru this same thing, and making the mistake of ordering the wrong one, I can confirm 100% that ML3Z19H332AB is the right part for the 2024 Flash.
Thanks to @Jesse-Infotainment for the help correcting my mistake.
Wildneg
Kevin
Solution Architect
And you use both pieces that come with the part right? You replace the controller that is there (swap) and then hook up the gain controller in the coin slot....?
Let me check the infotainment site out. I think I saw it there a while back, if they sell it.
Do you have any notes on specific updates with forscan off hand? Would save me some research.
Appreciate the info though! Feeling good about this upgrade now.
mxracer
Dan
Yes, both parts are needed. The controller that is in the truck does not have the right hardware nor firmware to actually work as a brake controller.
In Forscan just go into APIM and IPC and search for trailer. You'll see all the settings that are disabled, change them to enabled.
If you get the whole kit from inforteinment you won't need forscan. They have the "genie" programmer that will do it all for you by just plugging it into the OBDII port. If you already have it maybe Jesse can help with the kit without the genie. Jesse may be able to confirm but, if you don't get the genie you may also need FDRS. I had to use it to write the VIN to the module and run a couple of config procedures to get mine to work but I am not sure whether that was cause I dicked something up using the wrong controller the first time or it is part of the process.
If they don't have the kit PM me and I have a potential 2nd source for it but try infotainment first as they help us here on the forum.
Jesse-Infotainment
2024 F150 Lightning Platinum
YEah, We have a programmer that we include with the trailer brake kit.. for those that arent familiar or comfortable with Forscan.
THanks
priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
The kit is available here with the programmer.
The part without the programmer is available here directly from Ford, but is currently back ordered.
Wildneg
Kevin
Solution Architect
Assuming I would select the 2021 to 2023.... Even though I have a 2024? Programmer would still work ok?
Smokewagun
Bob
N. Illinois
2024 Ford Lightning ER
Interested about 24’s as well. I have the controller I my truck, but my sons doesn’t have one. He is proficient in Forescsn, but Forescan doesn’t support the 2024’s. He installed the brake controller, but even the dealer couldn’t program it. They said his truck wasn’t built with the controller, and he’d have to have a truck with the max trailer tow like me. I call hogwash. States around here require brakes on anything 2,000# GWR or more.
Jesse-Infotainment
FOrscan works fine with 24s
Smokewagun
Bob
N. Illinois
Thanks Jesse. I’ll have to ask him what trouble he was having.
Flash150
Glenn
US-MN
F150 Lightning Flash
THanks
I did the Infotainment upgrade with my 2024 Flash and it worked fine and glad to have the integrated brake controller and it was an easy update. Replace the module under the dash, pop off the coin slot holder and connect the brake controller gain switch/manual switch and then plug the Genie programmer into the OBD port and it is enabled.
Smokewagun
Bob
N. Illinois
My son got it to work, but it displays a trouble code when trailer is initially hooked up. Appears on startup. Once cleared, it’s gone.
Jesse-Infotainment
Either got the wrong part number or changes needed werent all made correctly.
