Easter eggs
RLXXI
3rd rock
Automotive Technician
Anyone found them? I found one and was told there are many more but wasn't specific. If you open the sketch app and tap the top of the screen where the word "Sketch" is spelled out fast, it animates drawing a rose on screen.
Aaron
2024 F150 Lightning FLASH, 2023 Kia Niro EV WIND
Maker of Yes Milady! Eggcellent seasoning mix
Enter your pin on the side of the drivers door to unlock the doors and then hit "8" - it will pop open the frunk.
RLXXI
RLXXI
3rd rock
They deleted the pin pad on 25 and newer trucks. It's an option now.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
That’s so cool 😎 just tried it out, thx 🙏
Ted23Lightning
Ted
Anyone found them? I found one and was told there are many more but wasn't specific. If you open the sketch app and tap the top center of the screen 4 times fast, it animates drawing a rose on screen.
Do u have to hit it before the application starts?
Ford F-150 Lightning Easter eggs IMG_4590
RLXXI
RLXXI
3rd rock
At the top where it's spelled out "Sketch", tap the word itself and this draws itself on screen.
Ford F-150 Lightning Easter eggs sketch ros
astrand1
Alex
Studio truck driver
FYI you can still add the wired keypad on a 25. At this point the harness is still in the door.
Scorpio3d
SS/IBA car wash owner
I would still check first!
You would also need the proper trim on the door for the keypad, but should be doable!
astrand1
Alex
Studio truck driver
You would also need the proper trim on the door to for the keypad, but should be doable!
Oh it’s very doable and cheaper than that stupid stick on one. Yes as we get deeper into 25 and job 2 and beyond trucks it would be a good idea to pop off the driver door card to verify that the plug is there. On higher trim trucks it should be.
RLXXI
RLXXI
3rd rock
Where, cut a hole in the door to mount it? lol
astrand1
Alex
Studio truck driver
Nope. Hole is already there. All you do is buy the piller with keypad and then take off the blank piller and install the new one with keypad. There are videos on YouTube showing it being done. It’s one of the easier plug n play mods.
RLXXI
RLXXI
3rd rock
They moved it to the door pillar trim I see. My other truck is a 2013 and it's in the driver door handle assembly. I'm definitely going to pop the door panel off and see if the harness is there. The keyless entry module should have a sticker on it with the actual code to use and I'll be super happy if that's all it takes, the part is less than 200.
astrand1
Alex
Studio truck driver
Hopefully it is. It should be clipped inside the door maybe kinda near the latch assembly. Let us know what you find.
RLXXI
RLXXI
3rd rock
Well, I've been looking deeper into the parts, the keypad and pillar trim and ran into an issue, the 25 Flash has piano black pillar trim, the only thing I can find in Ford parts is either chrome or black stainless, neither of which will match the other doors.
That's using a 24 ym to make sure the pillar trim has the cutout for the keypad. So it seems at first and second glances the only way I would do this (if wiring is actually there) would be to replace all 4 doors pillar trim. That I am unwilling to do.
I still have to pull the door panels to replace the speakers when they arrive so I'll still post up if the wiring is actually in the door on this model.
Sentinal
Leigh
2023 F-150 Lightning XLT
any ideas if I can relocate the cable harness, keypad and pillar with cutout to the other side ? essentially, to what would actually be the passenger side door (right side) in USA.. the reason I ask is I'm in Australia and my truck has the keypad, but its on the "passenger" side of the vehicle here, since our drivers side is the opposite side of the vehicle to USA, and the vehicle has been converted, just the only thing they didnt relocate was that keypad lol.
