Canada Bought a used ford charging pro station 80A and want to know if missing these parts is a big deal
rkmohamm
Riz
Ford 150 Lighting
Got a good deal for a ford station pro off of facebook marketplace. Are they important? I emailed ford and they said they can’t supply these parts to me
I am missing:
  • 1 × 3-position connector (Communications)
  • 1 × 2-position connector (Dark Start – Battery Backup)
K6CCC
Glendora, Calif.
Only an issue if you are planning on feeding power from the truck to your house. If you are only going to charge your truck, those are not needed.
rkmohamm
Riz
Ford 150 Lighting
Do you know where I can get those parts or at least the part number or a picture of them. I called the number on the manual and went to a ford dealership and none of them helped me.
K6CCC
Glendora, Calif.
In theory, I should have them in my FCSP or the box. I doubt I would have tossed them. Not sure I remember where I put the box, but I'll take a look later. If nothing else I should be able to take a picture.
rkmohamm
Riz
Ford 150 Lighting
Thank you so much. Send it when you can.
ExCivilian
'22 Platinum
I don't remember those parts in either of my boxes and I received my FCSPs straight from the source.
Maybe they are already inside the unit itself but I'm not even sure what you're referring to, tbh.
Are you certain these parts don't come with the home integration system?
rkmohamm
Riz
Ford 150 Lighting
Hey were you able to find them or at least have a picture of them?
rkmohamm
Riz
Ford 150 Lighting
When I look in the manual that comes with the charger its says:
1 – 80A Charger
1 – Mounting Bracket
2 – 3/8” x 2-1/2” LG Flange Hex Head Lag Bolts
6 – (T20) Torx-head Dog Point Screws – M4 x 0.7 x 16 mm (2 extra)
1 – Connector – 3 position (Communications)
1 – Connector – 2 position (Dark Start – Battery Backup)
I have everything but the connectors. I look on videos online and they look like little green things packed with the screws when opening the box
I sold mine but iirc, the connectors you are talking about came in a baggie. Was just a 2-position and 3-position Phoenix connector. Cheap on Amazon. Note, there are at least two different pitch sizes. Measure the distance between the pin connectors on your board. I am aware of 3.81 mm and 5.08 mm pitch.
But you only need them if you are installing the ~$10,000 Home Integration System. A lot of folks instead are using the 240V, 30A bed outlet connected through some type of generator interface to their electrical panel. Bypasses the FCSP altogether.
Followup to above. Here is where they plug in I believe, The yellow circle on the left is the 2-pin Dark Start/Battery Back-up. The circle on the right is the 3-pin Comm (may be the top or bottom one). This pic with (with my circles added) comes from @Aminorjourney's post here.
Ford F-150 Lightning Bought a used ford charging pro station 80A and want to know if missing these parts is a big deal 1755526237633-d
