Ppo enable with ignition off?
Rtashiro
Ryan
Winnipeg, MB, Canada
I see that this is offered as a feature on new trucks to enable the pro power with ignition off but was wondering if anyone has been able to enable this on 2023 lariat models using forscan?
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
So I just reached out to Jesse about this last night and successfully enabled this on my 2022. Here's how its done:
Jesse-Infotainment said:
As long as the truck is fully updated in FDRS you should be able to do this pretty easy
Set
7D0-10-03
XXXX XX2X XXxx
7D0-10-04
XXXC XXXX XXxx
tHAT SHOULD ENABLE THE SWITH to leave outlets on. That should be all you need to do.
Rtashiro
Rtashiro
Ryan
Which module would these changes be in?
Thanks for this! Looking for successful feedback from 22-23 owners. I posted my analysis in the main FORScan thread here for those interested in the technical details.
21st Century Truck
Martin
My 2023 XLT Option 312A seems to have taken this successfully, as described above. I had a "0" and a "0" and changed to "2" and "C".
Here is a quick summary of Pro Power Onboard with the truck off with some useful links.
Starting with the 2024 model year, Ford added an option in the Pro Power Onboard settings to "Keep On When Vehicle is Off".
Ford F-150 Lightning Ppo enable with ignition off? 1772032688301-nc
It was soon discovered that when operating PPOB with truck off, that the outlets would turn off if the load was less than ~90 Watts for ~6 minutes. This does not occur if you leave the truck on.
@kubel developed a work-around using a timer and heater in post 84 of that thread.
@Jesse-Infotainment found a way for 22-23 owners to enable this feature using FORScan. It is outlined in the main FORScan thread here. This mod for 22-23's requires a PCM update that came out in early 2025 available via FDRS. The Charge Port OTAs that came in early 2026 will also work (PT-25.13.12 or PT-25.8.5).
