K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
I discovered that the side mirrors are not made of glass and can be scratched somewhat easily.
Here's how I discovered this. I had put a convex stick on mirror onto the drivers side mirror, but did not like where I put it. As is normal, these are held on with double sided foam tape. The easy way to remove those is to use dental floss as a saw between normal mirror and the add on. It will easily cut the foam tape. Once the mirror is off, then Goo Gone and some gentle scraping with a knife blade will get the remaining tape off. The removal worked fine, but after I was done, I could see some minor scratches on the mirror surface. A glass surface will not be harmed by gentle use of a knife as described, so I have to assume that the mirror is a plastic material.
Not enough to be a problem, just enough to notice.
