tls
Just to close out one more open question - I have been told by a Ford engineer, though not one who works in this particular area, that Ford rates its wheels lower on the front than the rear because the front wheels take more lateral forces in cornering and in off-road/"urban" driving (curb strikes, potholes, etc). If this is right, it might make sense to discount the rating of an aftermarket wheel to a similar degree when it's on the front - but a 2500lb rated wheel is going to be sufficient either way.
Some of the older OEM F150 wheels (both those shown in the chart I linked to and others you can find in the same book for prior years) have much, much lower ratings, and some current wheels do too. It always makes sense to check before assuming if it bolts up, it's safe (maybe it would have made sense for Ford to use the 8 lug pattern from the F250 for the Lightning, but then everything would cost more and we'd have less options...).
