Power Train Malfunction Alert: Fix Post #8 & 18
GoodSam
Good
occupying space
If this battery tanks Imo it will point to the DC charging.
Need at least a 12Vdc socket LED display of voltage going to battery. A OBD bluetooth plug-in adapter and the CarScanner App might tell a bit more.
ALyn
Al
Kansas City
Ford F-150 Lightning
Anyone else receive this? Driving this morning - everything fine - and alert on drivers screen Pull Over Safely and Stop.
My app says ā€œpower train malfunction. You can drive until you stop vehicle but then won’t start. Contact Ford and have your vehicle towed to facility of your choiceā€
I called a local Ford service and told him. He looked up my VIn and said it’s just a recall / APM software update. He also said I can keep driving and just schedule an appt.
Given the dramatic alert in the truck that seems odd. Anyone else getting this?
Just shared this with another poster...
I’m living this right now too 😊 My 2022 Platinum threw the infamous orange (or is it red?) ring of death about three weeks ago. The dealer traced it to the onboard charger and ordered the replacement part—but I still don’t have a delivery date.
They were kind enough to set me up with a rental for the next month, so I’m not too stressed. That said, with the sub-zero temps we’ve been having, the truck has gone from holding about 60 miles of charge down to just 24. I’ve tried all the usual tricks (including lowering the charge rate), but no luck so far.
My GPT says there’s a built-in failsafe that limits charging to protect the rest of the system, which would explain why it won’t go past 60—or now 24—miles. I’m not 100% sure that’s accurate, but it does make sense.
Even with the inconvenience, I still love this truck. It’s just that good. From everything I’ve read, this isn’t an unusual issue—the error message just tends to misdiagnose the root cause.
Good luck—you’re not alone!
ScottC
ScottC
Scott
2024 Ford F-150 Flash
Thanks @ALyn.
Net result of all this is my truck locked up twice, was towed to two different Ford Dealers (which they paid for - no hassles there). Both service techs said it was a bitch to get truck 12v battery charged up...but finally they got there and all error codes cleared. Both dealerships refused to swap out the battery because they said it held a charge and Ford policy is they will not pay the dealer back.
So - in the end I paid Ford to put in a fresh battery and I kept the other one. I'm also out about $200 for a Lyft the night the truck broke down and a one-way car rental with my family to get them back home.
I drove yesterday 200 miles without incident and this am my display shows 100/100. Ironic that a sophisticated energy system as the Lightning is grounded by the oldest of battery technology.
Sc954rr
Scott
NJ
F-150 Lightning, Volvo XC90
Just had this happen to my 22 lightning 2/6/26 which is currently sitting at dealer and all I am getting is its throwing a ton of error codes. Will update with findings when I have answers.
ALyn
Al
Kansas City
I to have a 22 lightning. Just picked mine up from the Dealer Service Center. Went in with the Powertrain and a few other error codes, all tied back to a bad module in the battery pack. The cooling liquid leaked from the pack. They had to replace the "Battery Module High Voltage (Array)". It took 3.5 weeks for the parts to get in and a couple of days to replace. The dealer provided a loaner. Luckily, the electronics are covered under warranty for five years. I've heard of a number of dealers that have had to wait much longer for the parts, so I'm feeling lucky about that. I'm thrilled to have it back as I love this truck. Wishing you luck with the resolve but know your patience may be tested waiting on parts. Powertrain Warranty is 5 years but the Battery and other EV components are covered for 8 years or 100k miles.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Alyn thanks for your posts:
On Jan 27th:
Now on Feb. 10th you reported:
This sounds like Bad luck indeed. Did your truck need the charger & one module? And what is this about leaks in the pack? Were you able to get a copy of their work report? Can you provide any more details?
ALyn
Al
Kansas City
They replaced two modules. They told me they were going to change out the OBC but i don't see that on the work order. Can't get the upload function on the site to work for a pic of the work order. The truck is back to perfect. Push the dealer for a loaner (my dealer offered it immediately) because the parts take a few weeks to arrive. It took about two days to do the repair.
Sc954rr
Scott
NJ
Update***just got truck back almost 2 weeks later...had two bad battery arrays was the original issue..once replaced they had to replace the 12V battery twice cause it wouldn't let cells charge along with high voltage fuse...after that they had to call tech support since there was no voltage reading on any cells, glad to say truck runs as good as new again!
rtk11226
Rusty
Houston Area,Tx
2023 Ford Lightning/1991 Chev 1500/1976 Corvette
Retired IT/Engineer
Just had this happen to me yesterday. I had 3 tows cancel on me and had to leave the truck in a parking lot overnight. A wrecker finally got to it this morning and found the 12V battery completely dead. I had to coach him over the phone on opening the frunk, jumping the battery, and attempting to get the truck in neutral… but no luck. It seems the battery was completely dead and ā€œunjumpableā€. i had the dealership tow it and it was at their site in 30 minutes. The service manager said he would get with me tomorrow. Iā€˜m keeping my fingers crossed for an insignificant 12v issue because this truck has been near perfect since delivery.
ScottC
ScottC
Scott
Sorry to hear that. What i've found is that it takes a couple of days. They just put it on Battery minder until it comes alive. This happened twice in a 2 week period at the beginning of the year. I ended up buying a new battery (Ford would not replace) and drive around with the old one and a battery minder in a milk crate in the back.
Beyond that issue (the 12v) I've put 25K miles on my truck in about 14 months. The best vehicle i've owned.
rtk11226
Rusty
Houston Area,Tx
Retired IT/Engineer
The service manager called yesterday with good news/bad news…. My truck was restored to service with the installation of a new 12v battery. Bad news was when they were looking for the coolant leak I had also reported, they found rodent damage to a wiring harness and coolant lines. It could be around $1500. Damned raccoons! Any advice other than getting a dog?
