Both Front USB Ports Will Not Charge
DNap4
22’ F-150 Lightning XLT SR
They came back on this morning ... I tried rebooting and everything yesterday to no avail. It is obviously a software issue. Anyone any ideas what would cause this?
Do you mean these ports?
Ford F-150 Lightning Both Front USB Ports Will Not Charge IMG_0756
Have you tried wiggling the input to see if it’s connection issue? I have these and apparently these are very crappy usb outlets from what I’ve read online and have been known to fail. Mine I have to wiggle it into position to get it to connect, but then it is very loose and will disconnect if i don’t hold it in place.
Here’s a video to replace it if this is the one you’re talking about:
strmwzrd
strmwzrd
Nebo, NC
F-150 Lightning Lariat
I have the same issue. Both USB media ports are now dead. Did it require a module and if so which one?
I am sorry, I thought I updated this issue. Dealership changed the module AND did not test it afterwards. When I got home the ports were still dead. Eventually the cable going under the passenger seat was replaced for the fix. See attached.
Ford F-150 Lightning Both Front USB Ports Will Not Charge 20260219_094212
strmwzrd
strmwzrd
Nebo, NC
In case you need the module PN--ML3Z-19A387-D.
galstaf
North Georgia
2015 LEAF x 2, 2022 F150 Lightning Lariat ER (511A trim)
community offgrid training
Wow.. sounds about right!!
Thanks for the update. It seems to be working again now, so it appears to be a software issue. I guess I will keep an eye on it !
brirr76
Midwest / KC
2024 F150 Flash / 9.6kw + Max Tow - Midwest / KC
I use those ports every day but yesterday after work they were just dead. On the way to work they were fine. So I tried the sync soft-reset and they immediately started working again. Weird.
galstaf
North Georgia
Right?! Mine have not been a problem since. What did you do to reset just in case?
brirr76
Midwest / KC
Soft reset, by pressing steering wheel buttons Volume Down and Next Song and holding at same time for about 5 seconds.
