Forscan spreadsheet F150 Lightning platinum 2024
Lightman24
Svenning
Norway
2024 F150 lightning Platinum (USA)
Has anyone made a spreadsheet with FORScan codes for the F-150 Lightning Platinum 2024 model? Is there any difference in the codes between Lariat, Flash, or Platinum? Thanks in advance.
You will not find spreadsheets specific to model. Some sheets are year specific. The only difference in mods is that some may not be applicable to lower trims or certain years because they lack certain hardware.
The main FORScan thread should work for for you.
I see you are from Norway. That may also present differences if any of your modules were altered for import. Also, if you post questions somewhere else on this forum, it would be helpful if you updated your Vehicle Details to add 2024 Platinum so that info is always there.
Ford F-150 Lightning Forscan spreadsheet F150 Lightning platinum 2024 1772062187576-cx
Lightman24
Svenning
Norway
Thanks for the reply. Can I cause any major issues by using the wrong codes when working in FORScan? I will of course back up the AsBuilt.
My main goals are to activate the front camera so it turns on automatically, make traffic sign recognition use the camera only, and enable glare-free.
I don’t know about major issues. But if you enter the wrong code you could disable functionality (examples). Double check your work and only use mods verified to work in this forum.
The AsBuilt files that Forscan changes are like Windows’ Registry or INI files. They tell the modules what features and options you have. But they don’t change a module’s code.
Forscan can change a module’s code via side loading but that‘s an advanced topic that only a few get into. Those changes can brick a module (usually recoverable).
Lightman24
Svenning
Norway
