Wireless Phone Charging for Lariat and Below Models
Knickell
Knickell
Kyle
Mazda Protege, Ford F-150
The built in charger is garbage. It will not stay connected to the wireless charging pad whether case on or off. I have an iphone12Pro and it's a pain in the ass. I have switched to a magsafe charger but before that, if you want something close, this works great. Never had an issue.
Amazon.com: Wireless Charging Pad Car 15W 10W 7.5W Q Fast Car Wireless Charger Pad Stand Station Mat, Phone Holder Car Wireless Charger Mount for iPhone 12/12 Pro/11/11 Pro Max/XS Max/XR/X, Galaxy S10/S9/S8: Electronics
I wondered if that would be an issue. A lot of the built in charging pads being put in cars leave a lot do be desired charging and speed wise, especially when compared with a USB or USB-C cable.
Rod507
Georgia
2021 Ford F150 XLT Powerboost
She has Iphone 12 with a case and it works. It also works with her boyfriends phone, an older I phone with case. It was cheap, simple to install as it uses the USB charging port in the center console. Comes with the cord and everything. Even has a power button to turn it off when you leave the vehicle.
perfect I have an iPhone 12. I’ll be ordering this.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
You'd think it would be something that can be fixed in an ota update. Maybe just needs more juice, dunno. But you can be sitting still and it just disconnects from the charger.
Quite frankly, it's a pain getting your hand in there to get it sitting right.
I decided to go a different route that lets me see the phone.
Knickell
Knickell
Kyle
That is true about getting it to stay sitting right. They can certainly adjust the charging output, but probably have it tuned way down for liability purposes. I wonder if that setting can be modified in FORScan? ?
Cal_jammer
Scott
St. Louis
2021 F-150 XLT, 2013 Triumph Bonneville
Ajzride
Alan
Houston
Eng
Thought I would share my solution in case it gives ideas to others. Since I don’t have interior work space, I never need to fold down my shifter. I also didn’t want my phone tucked away in the media bin or console because I will forget it all the time. I 3D printed a platter that slides into the shifter recess, then bolted a mag safe charger through it. The charger is powered from the media bin USB-C port.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 3C648FBF-211A-4F18-BBD2-EF7F13EF2734
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 4B6D3CD0-2617-41B9-BCC6-1E73BAA7FBF4
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 1ECFA8D6-BF48-4241-8467-148F61450315
Papawsnow
Elliott
IN
2021 Lariat FX4
I have the Anker (2 actually) and use them in the house all the time. Love them and Anker in general. But the tray listed above has a much faster charge. I measured it very near 7.5w on my iPhone 11, which is at it's limit I believe. The only "negative" is that its inside the console. That has not been an issue for me. Also, I was getting ~ 5v from all the USB A and C outlets in the truck, which pleasantly surprised me. So, if you need the very fastest - plug it in, the same is true at home. But, I am very happy with the tray. A couple more notes: it appears that the rear and in console outlets are powered even when the truck is off. (I let it go for several minutes). The outlets at the dash turn off with the truck. Also, the USB A that is on the top of the tray was SUPER slow, I have even wondered if it was defective, but it did work. One last thing, there were some reviews about it getting hot. I used it on my workbench for a couple days to keep an eye on it. I did not have any issue. That said, the cooling ports are on the bottom, pretty sure you don't want to smash it down on a sweater in the console, give it some air.
Ajzride
Alan
Houston
Eng
Heavishot
Kerry
DFW, TX
2021 Platinum F-150
sbreech
Steve
Central Ohio
'21 F150 STX, Lead Foot Grey
Systems Administrator
Thanks for this tip! I ordered the wireless charger and 6" cable (90 degree USB-C to 90 degree micro USB) and it works like a champ. It allows me to keep my USB flash drive with my music plugged into the standard USB port while I charge my iPhone wirelessly out of the way all while using wireless Apple Carplay. This was an awesome tip!
ZWARRIOR
2021 Ford F-150 Lariat 501A 2.7l
Software Engineer
@Knickell hey, where did you get that key fob cover? I beem looking for a good one for ages
Knickell
Knickell
Kyle
Briansk12
Houston
2021 F-150 PowerBoost
I just came up with a way to add MagSafe charger to the console. Same principle as the wireless charge you can get but that really didn’t work to good for me. I just bought a center console organizer, MagSafe charger, and an adapter to mount the MagSafe charger in from Etsy. Basically just drilled a 2.5 inch hole in the organizer, snapped the adapter in and put the charger in. I also installed a dedicated PD USB C charging socket that will allow for faster charging. Thinking I might get brave and do the same thing in the media compartment.
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 0BE194BC-73CF-43BE-8076-EE3CBFA39BD3
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 1436CA30-4037-469B-894D-9ECE8CEB7AC1
Ford F-150 Lightning Wireless Phone Charging for Lariat and Below Models 4617D260-606B-4453-B191-C4894DF44A18
Knickell
Knickell
Kyle
Looks good! Looks like you did intrude right way!
Orlando150
Orlando, FL
Ford
I've been meaning to do this since I picked up my F-150. I think its nonsense how some Lariats can top $75,000, and XLTs and XL can easily crest $50,000 and somehow we are blocked out of having the wireless charging option that is afforded to the King Ranch, Platinum, and Limited trims.
Well, friends, I've found a pretty good, if not better, alternative for us lowly Lariat lovers who want a wireless phone charging option for their trucks.
Here is what I did to combat Ford's cost cutting:
I have used Anker phone related products in the past, and have had pretty good luck with them. Way back in October when I was in the process of placing my order, I was considering buying one of their wireless charging pads for the truck. since that time, it looks like Anker has released a smaller, more powerful model.
I picked up the Anker PowerWave Base Pad. This item seems extremely well thought out especially for purposes of being used in the F-150s. The top and bottom surfaces have a rubber texture to better grip onto the phone as well as the surface it is placed on.
The device also has vents along the sides on the bottom to help with cooling, and mitigate overheating.
Here is a quick look at what comes in the box:
The Anker PowerWave is also able to charge through normal phone cases up to five millimeters thick.
I placed the PowerWave in the storage cubby directly underneath the Productivity Screen and climate controls. I also purchased a six inch USB to Micro USB cable to plug into the truck's USB port to run power to the PowerWave. I elected to get a ninety degree angle cable so it sits more flush with the device and saves as much of the cubby space as possible.
Here are a few pictures of it installed in the truck:
SUCCESS!! We have wireless charging in my F-150 Lariat!!!
Quick, easy, job done!!
I just wanted to say that I went with this exact setup (except I used the other cord to go the other way) and it's been great so far. Thank you.
