jwrezz
Sorry I searched. Bouncing between the lanes.What is ping pong?
Back and forth from line to line like ping pong the game, table tennis.What is ping pong?
I have the same trim and package as you. My situation was the same. I had to go into the dealership and have them adjust the camera settings to account for the leveling kit. After that was done it continued to do it for a little bit and then stopped. My conclusions were that it must have self learned the new settings and calibrated more through me driving. No idea is if this is what happened but it seemed logical enough in my mind. Also one thing I’ve noticed is that it does not like the HOV lane, the different lines seems to screw it up. So I would recommend using normal lanes with regular dash lines on each side. I would definitely remove the AI thing though and start testing with fresh factory settings.Hey Guys. I installed a leveling kit in November. Ever since my bluecruise would ping pong at any speed.
Long story but I added Comma AI self driving. I am having the same issues with the comma AI unit. It ping pongs bad. At first. Any speed above 55 it would ping pong. I have data logs and a guy from f150 forum is helping me sort through the issues. At first we tried changing some code. It improved slightly. I could get up to about 65 70 before it would ping pong on straight roads. It drives perfectly around curves.
I just got the truck re aligned today and I found out the shop that lifted my truck did a crappy alignment. So after the re align it's better but it still ping pongs.
I tried blue cruise again and it's like it's the same issue as thr AI. So for sure I don't have to get the camera aligned. It has nothing to do with that. The comma AI has its own camera and I can calibrate the system at any time. Both the comma and the ford system are having the same issues leading me to believe it's something to do with the alignment.
Does anyone with functioning bluecruise have pictures of your alignment settings after the lift that you can share with me? Especially if you have a lariat with a tow package
*** I have a 2 inch leveling kit***
Thank you
When I recalibrated my IPMA with FDRS after the level, FDRS specifically tells you that it is not designed for this and if the suspension was modified, to not measure the wheel arch height and return the vehicle back to stock.My ping pong issue was fixed. I had a recall on my truck about a year ago where they reflashed the ipma. I also think they reset the fender height value but im unsure as they did not acknowledge on the service ticket. (i'm pretty sure they did). The ping pong issue i had was substantially corrected.
So my experienceSorry I searched. Bouncing between the lanes.
So my experience is different but applies.Sorry I searched. Bouncing between the lanes.
