I have succesfully added 9.6 ProPower to a 2022 Lightning XLT SR EG311a. Are you looking to do this?Specifically if you have:
- 2024 or 2025
- Lariat
- Extended Range
- 9.6 kW
I might be interested in this! I have a 2025 ER Lariat, but only the 120 Volt outlet in the bed of the truck. It would be nice to have the 240 volt plug.I have succesfully added 9.6 ProPower to a 2022 Lightning XLT SR EG311a. Are you looking to do this?
This is me, but I have no idea how to get what you're looking for. If you have instructions, I can try to help!Specifically if you have:
- 2024 or 2025
- Lariat
- Extended Range
- 9.6 kW
I have exactly what you need in config changes and exactly what you need in hardware to go from 2.4 to 9.6 ProPower if this is what you're trying to do.Think I just need your vin to compare to mine to find the delta
One problem Ford has is they made a ton of trucks without ProPower and the supply of affordable trucks was very slim in a lot of areas. So, affectively 9.6kW ProPower was a much more expensive option than it appeared on the raw build sheet. If you buy the 7.2kW inverter on eBay (salvage) you can get it way cheaper, I got mine for 400. It's the wiring, the HV rear harness you need from Ford to make the install quick and OEM that is expensive.It was a $1200 must-have option when I was looking for a truck.
Awesome. Can you share that info?I have exactly what you need in config changes and exactly what you need in hardware to go from 2.4 to 9.6 ProPower if this is what you're trying to do.
And if you are ready I'd like to make a good DIY for the community on it. You'll have to be all in though b/c it will cost around $5k and you'll have to remove the bed to do it.
Send ;please.FYI most 24 and 25 Lariats don’t have it because it typically put the price above the 80k federal tax credit limit.
I have a VIN or 2 in my database I can send but am out or town until tomorrow. You can search carfax like I did and find one though. You have to look at the window sticker to confirm all options. But carfax has window stickers.
2024 Lariat with PPOB and MaxTow: 1FT6W5L74RWG09004Send ;please.
Sorry I haven't posted or started a DIY for this,, are you ready, are you wanting to do this now?Awesome. Can you share that info?
