- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Ford asked me to test the Climate bug so I ran three tests:
June 12 - Test #1 at approx. 2:14pm:
PPOB ON no load - cord plugged into bed outlet but 0 power being used
Heated seat OFF
PPOB with truck off - not enabled
Power Down Timer - OFF
Pressed Climate button in App
PPOB did not shut OFF but...
the app displayed an orange triangle with exclamation point inside, the truck honked three times with a pause in between each honk, and no climate was turned on inside the truck.
Because PPOB did not shut off, I did not do a bug report.
When inside the truck I turned the heated seats ON to HIGH for next test and the PPOB stayed ON.
June 12 - Test #2 at approx. 2:18pm:
Heated seat ON and on HIGH
PPOB with truck off - enabled
Turned truck OFF
PPOB shut OFF
2:20pm turned truck ON and recorded bug report
June 12 - Test #3 at approx. 2:44pm:
Heated seat OFF
A/C set to 72F and ON
Turned truck OFF
PPOB shut OFF
2:48pm turned truck ON and recorded bug report
c
Heated seat OFF
Turned truck OFF
PPOB shut OFF
Heated seat OFF
Turned truck OFF
PPOB shut OFF
c
