FloridaBreen
How do you Remove and Replace the 12V battery?
longer story:
So I was going to be away for 26 days and in the owners manual (Storing your vehicle) it said to disconnect the 12V battery if going to be stored for over 30 days - and I didnt disconnect the 12V battery - of course when i returned home the truck was 'dead' - no lights etc. After manually opening the FRUNK (thanks Ford for a poor design, 2 people are needed to open Frunk manually - one to hold the spring loaded manual release in the cab and the other to lift the frunk). I then checked the voltage directly to the 12V battery terminals, it measured 3.38v, I connected my portable jump start and immediately the Frunk lights came on and since driver door was open so did the dash. Truck "started" normally and I disconnected the jump battery with truck staying in "ready" mode. I then let the truck stay on for a little over an hour to charge the 12V battery. I also found that an update was in progress once the truck was on. In my experience 12V lead acid batteries do NOT like to be run down to very low voltages (under 10V) and it greatly impacts battery life. Looking more deeply in the owners manual I found "12V Battery - Troubleshooting" where it says
12V BATTERY
CHANGING THE 12V BATTERY
If the 12 volt battery needs servicing, see
your authorized dealer.
CHARGING THE 12V BATTERY
Your vehicle has a high voltage to low
voltage energy transfer feature that keeps
the 12-volt battery charged by the high
voltage battery. If the 12-volt battery level
is low, the high voltage battery transfers
energy to the 12-volt battery when the
vehicle is off.
12-volt battery depletion can still occur if
the high voltage battery state of charge is
low. See Preserving Your High Voltage
Battery (page 203).
Always take care not to deep discharge
the 12-volt battery as it may cause
premature wear.
In my case the HV battery was around 61% IIRC when I parked it and near the same when I returned - so the HVB should have had enough juice to keep the LVB charged even when OFF (see above)
searching previous posts regarding the 12V battery I didnt find any that actually removed and replaced the 12V battery, and as the manual states if it needs servicing see your authorized dealer. I am wondering why, is there some esoteric procedure to disconnect a 12V battery that is required by the Lightning?
longer story:
12V BATTERY
vehicle is off.
Battery (page 203).
premature wear.
