17” Winter Tires on Lariat
JayceeP
CAN
F150
Will 17” tires work on a Lariat? The stock configuration is 20” on mine (275/55R20) but I know 275/65R18 is another stock size on the Lariats. Not a lot of supply out there and I can pick up 17” barely used Michelin X-Ice already mounted on steel it’s for winter. So, the million dollar question:
Will 265/70R17 also work on the Lariats? The seller said they came off an F150 and said the 18” and 20” tire sizes are a match to the 17’s.
ryanc111
Ryan
Bozeman, MT
Leadfoot Powerboost
Generally speaking, yes. Unless you have the Max Tow package which requires 18" wheels do to the upgraded brakes.
Lippy
CA
2021 F-150 Powerboost
I’d like to pick up a set of used snows on rims. Where did you find them?
JayceeP
CAN
F150
I don’t have max tow just the standard tow package that came with 502a.
I found tires on Kijiji.
Mash150
Dale
21 King Ranch, 157, SQ , PB
Unskilled House Mechanic
Took these off of the 18 Lariat and the are fine. About a three kmph loss in speed. Eg. 100 kmph=97 km , 117 km =114 km
Selling these as the 21 KR is a PB and I don’t believe they would fit with the reg braking
Ford F-150 Lightning 17” Winter Tires on Lariat 37EF0602-B9A7-4B21-93DD-808F822301B5
