220v Plug Add On
Ericu571
Eric
Redding, ca
2024 Ford Lightning Lariat
I have a 2024 Lightening Lariat....it doesn't have the 220v plug in the bed. If I buy the part from Ford, can it just be added? Or am I stuck with just the two 120s?
jamelski
Sacramento
2024 Lariat
Stuck with 120. You not get the upgraded gen with 9.6 KW you got the standard 2.4kw that comes with truck
the upgraded 9.6kw ProPower requires an additional 240v 30amp INVERTER in the rear of the truck, supplying power to all of the bed outlets, both 240v and 120v...
with the 'standard' ProPower, there is a single 120v Inverter, supplying ALL outlets throughout the truck, at 20 amps.
the truck is actually wired DIFFERENTLY between the two options...
Ricks Lightning
Rick
Los Angeles
2023 F150 Lightning Pro, 2024 F150 Lightning Flash
Plumbing Contractor
$1200.00 factory option. My #1 requirement when I purchased both my Lightnings.
Tow package was #2.
Rick
Lightning...
