Aftermarket sub and amp
Froman
Austin
2023 XLT ER
I recently added a 10" IDQ sub and rockford 500w amp with a fox acoustics underseat box. I've been reading a few threads where people have 1000w setups in their lightnings. How does that fare for the 12v system? From what I've seen, the factory 12v system only has like 55amps to play with, a 1000w system would be around 100amps.
Ford F-150 Lightning Aftermarket sub and amp 1
Ford F-150 Lightning Aftermarket sub and amp 2
The key is that these add on systems rarely if ever play at full tilt. Few if any would ever put that strain on the 12v system. I added a 600w for the speakers and a 500 for the sub. Have never had any issues in almost 2 years.
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
I would like to do this. In previous trucks I always swapped out the head unit which isn't possible now. Did you use speaker level inputs?
jcm3
Rhode Island
F150 Lightning PRO [SQUISHED!] & 2nd Lightning PRO
how do you like it?
Froman
Austin
2023 XLT ER
The sub and amp? They're great. Sometimes i think maybe i should have gone with two tens and 1500w amp but it is so much better than stock if you like bass.
the plugnplaykit? It is awesome. Everything was a breeze to use. The lc2ipro is just okay. Setting it up is meh. Also i had to run a remote wire as i was unable to get the lc2ipro and rf amp to turn on without it (it has a setting to)
Froman
Austin
2023 XLT ER
Ended up blowing up the idq sub lol.
replaced the rf 500w with a jl audio 1000w amp and waiting on the new sundown classic 10” that i am replacing the idq with.
going to look into adding a 400-600w 4ch and replacing door speakers as well soon.
Reactions: GDN
3rd rock
Automotive Technician
1000W amp at 12v = 83.33A
1000W amp at 13.5v = 74.07A
