fhteagle
If he installs a NEMA 14-30R receptacle ("outlet"), you can buy a 14-30P (plug) to 14-50R adapter. This would let you plug in the 14-50 end of the EVSE, but does not guarantee the EVSE knows of the correct amp limit for the circuit.he can only do a 30 Amp breaker.
The OpenEVSE can be purchased with a 14-X plug that will fit in 14-30, 14-50, or 14-60 receptacles .
I know for sure the OpenEVSEs can be permanently or temporarily set to any amp limit between 6 (minimum J1772 spec) and the physical limits of the wiring and relay in the OpenEVSE. OpenEVSEs are not cheap, but are absolutely worth every penny, easily repairable, and the firmware is under continuous improvement.
The Ford travel charger is made by Webasto, yes? AFAIK those units take their limits from which plug pigtail is put in them. Does Webasto make/sell a 14-30 plug to Webasto proprietary pigtail?
