Bed Lighting Upgrade by Ruxifey
Pinero
Jordan
Down the bayou.
2021 Lariat Sport 5.0 SCREW FX4
High Voltage Technician
I’ve used some of the Ruxify solutions on my last truck without issue, so I looked around to see what they make that will work with the 21 f150. Turns out they make a plug and play bed light fixture.
Ruxifey LED F150 bed light
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey 35A55F8B-7AF4-4D87-A45D-7821E2941FA4
Left: OEM
Right: Ruxifey
INSTALL:
I was already under the truck installing new rear shocks, so I simply reached up to depress the clip from underneath. This was easily reachable.
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey 44B19A1B-5777-4713-80B3-DE535D7D1A8B
Use a panel tool to remove the wire harness from the OEM assembly. Unclip the wire harness. Replace with new assembly, and repeat steps in reverse.
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey 9E141BB6-C5C9-4EBC-8311-3F398E19C37D
I did not take comparison pictures, but the result is a much brighter cool white light. For the $20 price tag, I would definitely recommend these to anyone who works out of the bed a lot.
Floatman
Mount Hope, Ontario, Canada
2018 Lariat 500A, 2021 lariat 502A
Retired- Livin' the Dream
Purchased and installed. Certainly brighter than originals. Thanks for the link
jeffcrum
Jeff
Slidell, LA
Computer programmer
Just ordered. On sale and extra 10% off. Under $15.
ETA:. They arrived. I installed one. Will wait until dark for pictures of each side before installing the other.
jeffcrum
Jeff
Slidell, LA
Computer programmer
Installed. First is original left. Second is new right. Third is center shot with both new in.
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey IMG_20210717_204229809
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey IMG_20210717_204237529
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey IMG_20210717_204632192
I don't think pictures show it. But, certainly brighter with new. My neighbor was here and agrees.
At $15 all good.
TheRealSOB
Shawn
Apple Valley, MN
2021 F-150 2.7 eco Space White
I'm very interested in these. The link from the OP brings me to a product that says it's intended for a 2015-17 F150 or Raptor 17-18. Can someone confirm that is what I should buy or is it a bad link?
Dmusick757
Donnie
Oxford alabama
2021 f150 powerboost xl
What about the on/off switch. Where is that mounted and is it plug and play as well?
jeffcrum
Jeff
Slidell, LA
Computer programmer
That is the one.
jeffcrum
Jeff
Slidell, LA
Computer programmer
Same switch that was already in the bed. These replaced what was there.
Dmusick757
Donnie
Oxford alabama
Oh ok I was thinking it was an addition to if you didn't opt for it when you bought the truck. Cause the blanks are there for the lights, I misunderstood sorry.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
For anyone else that gets these, is there any chance you could get a photo of the entire bed with one side as the original lights and the other side the upgraded lights? It may be easier to see the difference if both are in the same picture
jeffcrum
Jeff
Slidell, LA
Computer programmer
My third picture was old on left and new on right.
The picture did not show what our eyes saw. It looked much better in person.
YOCUBED
Tuscaloosa, AL
2020 GLE 450, 2016 BMW M3, 2021 F150 Limited
Emergency Physician
I can confirm that pics really don't do it any justice. Here are 2 pics of the new vs old in my truck. in both pics the new Ruxify lights are on the driver's side. In person the difference is quite noticeable but it just doesn't come through well when photographed.
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey 20210706_173617
Ford F-150 Lightning Bed Lighting Upgrade by Ruxifey 20210706_173636
imnuts
Dirty Jerz
Facilities Engineer
Thank you both. @jeffcrum I didn't realize the last picture had both lights in it. @YOCUBED I can kinda see the difference in your picture, but you're both right, it is subtle in the pictures.
TXENG89
Will
2021 F150
Just curious, were our trucks supposed to come with lights on both sides of the box or just one side?
