Boxlink cleats
Vulnox
Livonia, MI
Others are mentioning that theirs came with the H style. I think this is a critical thing you should look into. My late 2024 came with the same as your picture, but I had a brown box that under my rear seats that contained the style in bmwhitetx's post with the green check box. I had to unscrew the originals and install those.
That allows you to connect e-track style connections like these:
https://www.harborfreight.com/e-track-tie-off-strap-with-d-ring-56745.html
I got four of those for the bed and also got a couple of these:
https://www.harborfreight.com/2-in-x-22-in32-in-e-track-adjustable-bungee-strap-2-pack-70972.html
Which are great for propane tanks and smaller things that stay to the back of the bed.
I see others in here mentioning also having the box. I know more changes came in 2025, but even if you have another style in your brown box floating around in the truck, I would look for that box. As I said mine, along with some other cables/brackets, was under the rear seats in the storage bin.
jimallen
Ohio
2022 Lightning Lariat ER; 2021 Mach-E GT
Boxlink is such a cool idea that has almost no support out of the OEM tie downs. At least, from the quick searching I did on it in the past. Anybody have any cool boxlink options?
I have the Rad Straps https://radtruckstraps.com/ that are convenient and have lasted almost 3 years so far without any problems.
I'm also building out a full MOLLE panel system with Packout box mounts from BuiltRight. https://builtrightind.com/. Very sturdy stuff, all made in the US, if that's important to you.
I would love to see the reason for adding this different bracket. The "save costs" argument is dead in the water, because they save cost by providing nothing - as some trims always were. In this case, providing the bracket AND the kit makes zero sense to me.
ryun
Earth
Those are cool! Though, they don't seem to use the cleat that's already installed. I was thinking of something that used the system installed by the factory rather than switching it out and using the bolt points.
