Canadian Winters (Dealer told me F150 Lightning not the truck for me)
Kev12345
Ram 1500
what's the issue with charging before you head back? get the lightning! your dealer wants you in for oil changes and other ICE maintenance.
columbiaskier
Calgary
2022 Lightning Lariat ER
I may be too late on this response but I mean at below -20 I can’t make it back to the Canmore charging station. Meaning yes I could make it to Louise without stopping, but I wouldn’t make it back. So yes two stops on the Canmore charge station or risk it and hope to get lucky and score one of the two level two destination chargers at Louise.
In regular conditions I would do one stop at the charging station on the round trip from Calgary. I have pushed it and made the full 360 km trip but this means coming back at below 15% battery. I usually opt for the fast charge cause with a 10-20 minute stop I can easily add the juice I need to have a good buffer.
columbiaskier
Calgary
In summer I get 400-430 highway. So yes could easily do the trip back and forth. Like I say normally in winter I do one stop but below -20C the range starts to really hurt. 2022 Lightning doesn’t have a heat pump so that’s holding its winter range back a bit. Although I’ll defer to more knowledgeable people on the forum when it comes to heat pump effectiveness as really cold temps
columbiaskier
Calgary
EPA highway range for lightning is around 430 km. However due to its aerodynamics the Lightning’s efficiency goes down a lot if you drive at the speeds most people drive at. Lot’s in the forum about this.
I’d say my summer highway range is more like 400 km if I drive 110-120 km/h.
The distance being talked about is 260 km or 65% of the “real” highway range. 35% efficiency loss for extreme cold to me sounds typical for an EV.
Like some people have said on the forum it’s theoretically possible if you precondition, drive slow, don’t have a headwind etc.
In other words if the stars align and you’re comfortable barely making it back to the house in frost bite conditions then yes it is doable. But for me I’ll stick to an extra charge to keep a buffer.
Markip
150Lightning!
F150 lightning
Hi everyone I'm a recently new lightning owner 2025 xlt love the truck anxious to see the affects of winter I commute from Barrie to Toronto up to 3 times per week.
21st Century Truck
Martin
I've tried the local Petro Canada fast chargers many times over several months. They are terrible and more often down than working. Until they improve, I would not count on them in the dead of winter. I'd recommend checking the reviews/comments on Plugshare for real world results of the actual chargers you'd need to rely on if selection is minimal. You can also check reviews on Google maps searching "Charging Stations". Range anxiety sucks, especially when you buy such an expensive vehicle.
I just LOVE Your TinTin avatar! It made me smile thru my morning coffee :clap:
