lister coggs
- First Name
- Lister
- Dec 26, 2023
- Barrie, Ontario
- 2022 Lariat SR
Thanks for the quick reply!I would say, for the level of simplicity it sounds like you're looking for, probably not. The complexity isn't majorly the connector to the shifter, it's that a lot of the wiring is tied into that center console. Once you remove the center console and free the wiring, it's not difficult to relocate a rotary shifter but it's not trivial to uninstall the console and put it back in.
I was thinking the process would be straightforward (1-2 hours of work) if I followed a procedural tutorial like this one:
The question is where to go from there? Can I just connect the rotary shifter to one of the exposed plugs highlighted in the attached images with an adapter?
