Bespectacled Ape
Thx for the advice on Andersen. So I think you are recommending the non-chain type? The ones with friction bars?Back when I was researching, I saw bent plates with heavier trailers.
The other thing to note is that because you’re using chains you’re mostly controlling the up and down forces, not necessarily the forward back, side to side that some of the stiffer hitches do.
I am a scientist and my wife is an engineer, but I think anyone would struggle to understand all the physics involved. What I am thinking is, when the nose of the pickup dives, the hitch goes up and the bars go back, which surges the truck forward. Opposite happens when the nose bounces upward. I will have the engineer look at the tailgate cam to see if that hypothesis cks out.
I have never felt this before tho (and I have out at least 2k miles on that hitch). I have turned off sway control but it keeps coming back on, and yes it automatically switches to Tow Mode when I hook up the brakes.
I get there are hitch adjustments, but its either chain tension (plenty tight) or ball height. As mentioned the truck and trailer are fairly level. Since I don't have tools handy right now I laid out 200 bucks to have the ball raised to the max (as per 15 yr experienced installer) that won't contact the tailgate. I will see if that helps when we roll again but I doubt it.
I have not heard much feedback on software issues. Everyone is aware there are tip sensors in this truck right? I am still thinking there is some sloppy and reckless (hoping I don't get into a wreck) programming involved.
