Delete Lightbar and running boards
Grimsvotn
Ed
VT
2022 xlt ER
Has anyone unplugged or fully deleted the front lightbar (I have an XLT)? Can I just unplug it and have it tinted out?
I am sure I am in the minority here but I really like the work truck look of the pro.
I am also considering removing the running boards but worry about leaving the wiring for the board lights uncapped (it will corrode as I live in the salt belt). Has anyone fully removed these ( I see a lot of threads regarding upgrading the boards but nothing about fully removing them)
asianman35
Baltimore
2023 Antimatter Blue Pro
I should have the caps to my running board wiring, if youre interested. I have a pro that just had a dummy cap on them, but ive added the OEM running boards.
Grimsvotn
Ed
VT
2022 xlt ER
Does anyone have the light bar wire cap? I would be willing to buy that off you. Thanks!
BhamDCam
Birmingham
2023 F-150 Lightning Pro ER
Effonefiddy Lightning
Alfred
23 F150 Lightning SR Antimatter Blue /2023 Model Y
Ask someone with a Pro to make a trade.
Rainor
2024 F-150 Lightning Lariat
Does anyone know what the front light bar CAP does electrically? Does it have a loopback or resistor return signal or something or simply a dust-plug/cap?
digitys
Keith
Concord, New Hampshire
2023 Lightning Lariat ER
IT Consultant
So in Forscan I saw you could change the light bar brightness value. I think the default was 35, I’ll try lowering and see what happens. I’ll report back.
XtremevieW
2022 lightning
Any update on the dimming?
Havnt had a chance to get back in there. I will try this weekend!
You cannot change the light bar brightness. Early on folks assumed that. But the FORScan mod you are referring to changes the Daytime Running Lights brightness. See https://www.f150lightningforum.com/...ng-forscan-thread-version-2.23634/post-457770
Don't make those brighter FYI - you will likely have other drivers flash you because it looks like you have your high beams on.
