Fender Flares installed
boardriderb
2024 F-150 Lightning Flash
The front flares have a gap between the flare and the bumper. They do not fit perfectly but it is fine.
The rear flares have a 1" gap in the back in the mud flap section. It is on the back side of the flare where it should seal to the body. It does not affect function.
Tomentose
Thomas
2024 F-150 Lightning Lariat
Hm. so it doesnt sit tight to the bottom of the truck frame from the back side but the inside remains sealed? i guess the ICE versions rear panel drops lower than the EV. Im wondering how i could fill that gap. If you have any photos it would greatly help and if i come up with a fix then ill let you know!
stacyw
Stacy
indiana
2023 ford lightning
contractor
Hey, Late to the game i know but im going to get these fenders for my truck. I am curious if the drill holes line up at all or did you make new ones? Zooming in, it looks like the rear fender needs to be shaved down a bit where it pokes out (front bottom) by the 3 indents. It also looks to be a bit short on the front fenders, so same question about the stock holes versus new ones would be appreciated! i guess it just barely clears the charging port door by what i can see on the passenger side. can you confirm if thats correct?
stacyw
Stacy
indiana
2023 ford lightning
contractor
Your fender installation looks really clean! Are these a direct bolt on fit or did you have to make modifications to make them fit on the Lightning?
I put the same ones on my lightning and the holes do not line up with all the screws since the lightning is slightly different inside the wheel wells. I chose to add a couple extra holes in the flares to use all the screws so they would be a tight fit to the body
