FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS)
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dark_widgets_example_v2_1
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dark_widgets_example_v2_2
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) light_widgets_example_v2_1
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) light_widgets_example_v2_2
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
    Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dashboard_menu_example_1
    Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dashboard_menu_example_2
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
tardman91
Matt
Odessa, FL
2021 F150 STX
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 1645201017717
I still get this error. I am signed into iCloud. And I have Scriptable turned on in the iCloud menu. Any ideas?
va
2021 F150 XLT (HDPP+MTTP)
This is such a great update...really appreciate all your hard work!
JIMFOUNTAIN
2021 F150 SCREW PB 6.5' 701A
Massive updates! Thanks! Just installed the update and starting to play with (ahem test) it.
tonesto7
tonesto7
Anthony
Don't know how to help... Maybe the app is disabled under your cloud settings in iOS
smarty39
Kyle
Alberta, Canada
2021 F150 Velocity Blue Lariat Sport
Amazing work as always and a HUGE benefit to this community! Appreciate all the hard work!
CTYankee
Connecticut
2011 Edge
Outstanding work!
iceman77
Pete
Dallas
2022 Ford F-150 Platinum
Hey @tonesto7,
Any idea why I am getting this message ?
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 7811D8D6-6914-44E1-918E-547E6C812F4A
Is it perhaps that the script is trying to pull info from my old truck that I don’t own no more ? I tried to uninstall/reinstall the script, then the Scriptable app, even tried to remove any cached data from my iCloud drive, but the issue still persists.
tonesto7
tonesto7
Anthony
New Release: v2022.02.21.0
I just pushed out a new release which hopefully gets the large widgets working more consistently.
Please let me know the outcome!
tardman91
Matt
Odessa, FL
2021 F150 STX
I figured out the iCloud error! You need to have iCloud Drive enabled in the settings. I use it occasionally, and apps have saved data in there, but it wasn’t enabled in the iCloud settings for some reason. Once I toggled it on it worked fine. Thanks for your efforts!
tonesto7
tonesto7
Anthony
New Release: v2022.02.27.0
For all us Forscan and AsBuilt junkies, I want to thank @iceman77 for the idea of displaying module-info :)
Under the Advanced Info page, you can now download your asbuilt data from Ford and it will display all of the module info and it's asbuilt.
