Forscan adjust bass roll off?
Andrewbens
Modesto
Lightning
Mechanic
I was told after 2021 you couldn’t use Forscan to adjust the bass roll off when adding a subwoofer does anyone know if this is true?
BennyTheBeaver
2023 Lightning XLT ER
I tried a few weeks back to achieve this. My audio got completely cut out and I reverted back my changes. However, it's very possible I adjusted the wrong setting, or the settings are different from the sheet.
Andrewbens
Andrewbens
Modesto
Lightning
Mechanic
I was reading the 2015-2015 non amp trucks didn’t have the bass roll off issue and it was only a B&O problem so I’m not sure if this is true or not but I guess I’ll find out when everything is hooked up.
BennyTheBeaver
It seemed the 6 speaker Pro had the bass roll off issue. I used a KeyLoc to remedy, I struggled with tuning the KeyLoc though.
I tried the Forscan changes to our truck to flatten the EQ and eliminate Bass rolloff. All it did was completely cut audio going to other speakers. It's possible I made a mistake, but reverting my change brought back audio to all speakers.
I'm about to upgrade the 6 speaker system again. This time in my XLT. Has anyone been able to successfully flatten the EQ/Bass roll off via forscan on a Pro/XLT Lightning?
Maybe @SoundsGoodStereo can help.
Andrewbens
Andrewbens
Modesto
Lightning
Mechanic
I just installed my subs with 2 12s and 1,000 watts and the system seems to work great even had my audio buddies help me tune it and they were all surprised. Here’s what I used for my adapter from the headunit. I have the gain set to half way on it.
https://www.ebay.com/itm/1245657855...CuyCOBvS1m&var=&widget_ver=artemis&media=COPY
BennyTheBeaver
I am also upgrading all speakers (so running a 4-channel amp and a seperate all-in-one 10" sub/amp. I went a different direction, this time, with the harness as I finally an affordable harness solution:
https://a.co/d/0NLmKV1
(I also got the related extension kit https://catalog.pac-audio.com/catalog/amplifier-integration-harness/lphext17 )
When I added the sub to my previous Pro, the bass rolloff was noticeable and I was constantly turning down the sub at low volumes and up at high volumes. There are instructions for our gen F-150's to adjust the EQ curve, and turn it off completely, I tried it and it just cut my audio...
I'm hoping someone figures it out. (or I could be overlooking something)
Andrewbens
Andrewbens
Modesto
Lightning
Mechanic
So to be honest I haven’t adjusted mine at all I have the gain amp at 15% gain and rap will rattle everything in the truck and country will play the perfect amount of bass. I’ve read that the non amplified trucks did not have an issue with bass roll off but so far I haven’t noticed anything. Maybe a bass knob will help you out a little? I currently did not install mine.
BennyTheBeaver
I tried adjusting the Forscan settings on my XLT ER. The audio remained, unlike my Pro, but now there is an AM radio loop (everytime you pick a difference audio source it switches back to AM radio after 2 seconds). I'm giving up on the roll-off solution via Forscan. Time to put the KeyLoc back in.
