Found my 'Avalanche' XLT; Storm
Ned B
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
With the coming storm, I’ve decided that leaving my Volt at the terminal , and bring Storm home. Going to try to get my level 1 charger working (it threw a fault last time I tried it.) so that the battery will have a chance at staying warm the next few days. I don’t have a garage, and my level 2 charger won’t be installed for awhile. (DcFc is nice and all, but I am really looking forward to charging at home).
On a lighter note I just turned 10,009 miles.. on Storm!
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_6995
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_6996
The Lightning does really well in snow and ice, if you can avoid the other drivers!
Did your have the Ford Mobil Power Cord with it?
It has 240V and 120V dongles.
Not sure if you will get much battery warming out of the 120v one.
If you have an adequate circuit (240V on a 40A breaker) you can use the FMPC on it (it draws 30A and so 40A circuit is code). Most dryers are probably not on 40A, but often electric ranges are - but of course the outlet may be hard to get to.
Running a cord would be an issue too probably - the FMPC could be inside if you had a long enough J1772 extension.
But what did you use to power your Volt?
If it is J1772 it will plug into the top of the CCS1 in the charge port just fine.
I can use my old GE Watt Station J1772 with my Lightning at 32A if needed, I got a FCSP on eBay new in the box for $600 when I got the Lightning.
Good luck!
Ned B
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
I have a generic level 1 EVSE, from the volt. and a long enough cord to keep it plugged in,this is just to tide it over when the cold snap hits.
I got the truck used and no cable came with it. I have an Emporia Pro coming soon, and will be adding a dedicated 50a circuit so I can finally charge at home.
Nothing over 30a at the house, so it will have to ‘do’ or, I can go top it off as needed. Busy week at work , so it would be sitting at the terminal for several days. The Volt won’t mind.
I’m not worried about weather other than the cold zapping range from the SR battery.
All the best!
Ned
PS just when you think you’re the coolest kid at the charger, this guy shows up… note the plate
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_6998
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_6999
Reactions: chl
All the best!
Ned
Yes the cold does reduce the range, I haven't quantified it exactly but in Jan 2025, for the month I averaged 1.56 mi/kWh (no highway driving).
In mild spring weather it is almost double that on average.
So I'd say expect a 40 to 50 percent drop in range. Heating the cabin is only a small part of that.
Once you get your L2 EVSE, you can precondition while plugged in which will save battery power - preconditioning with L1 seems not very effective from some reports, I never tried that.
Enjoy!
Ned B
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
I just got my lectron Vortex NACS adapter, adding another way to charge Storm.
Here’s my two rides as well
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_7010
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_7008
StevenC56
Steven
Fresno California
The EV truck on the left must have a HUGE battery! :ROFLMAO:
So the adapter (NACS to CCS1) Ford sent out didn't come with your used truck?
They originally promised every Lightning owner would get one.
Some of us waited a long time for those - I ordered mine in May 2024, got it Feb 2025.
And there were some issues with the ones made by Lectron - had to recall them.
Ned B
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
Exactly, no EVSE or NACS adapter were with the truck. Given how low the mileage was, I’m okay buying replacements. Lectron manufacturers the Ford adapter, though they are unable to rebrand it for their own use. Other than a NACS to J-1772 adapter I’m pretty well set.
My emporia EVSE came in, just have to wait for the electrician to get some time for me
Reactions: chl
I believe at some point Tesla was making them for Ford but there were issues - not sure what the issues were, I think they were not producing them fast enough or something?.
Then Lectron made them but had a safety recall with some of them.
There was a defect that could damage the charge port!
It may have been from overheating, I don't remember the specifics.
But then at some point they fixed the problem and we all lived happily ever after:
"The National Highway Traffic Safety Administration issued a recall of the Lectron Vortex plug."
But that all happened in 2024 I think, long before I got mine.
There was a lot of discussion about all that on the forum at the time.
Ned B
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
Hey folks! hope everyone survived the weekend storm. Here in the shenandoah valley we had several hours of sleet following a couple of fluffy inches of snow, resulting in a very Solid snowpack. I'm a fairly, shall we say, hefty individual, and my yard & driveway still have snow that holds my weight.
On the truck front, I have about another week and a half before my level 2 charger gets installed, adding a dedicated 50A circuit and will be mounting the EVSE near my driveway. Originally planned on putting it on the shed where my level 1 charger has been, but there wasn't enough room in the panel and wiring to supply it. I can't wait, this deep cold snap is really a pain in the battery level.
I used my NACS adapter today and charged up Storm at the nearest Tesla SC site, Glad I won't be using that often, as it was a short cord and I had to be 'that guy' blocking a couple of chargers while I charged to 90% (yes, i know, but in this cold, I wanted as much as was practical to get). Despite their downsides, I'd rather go to the Electrify America site on the way home from my truck terminal, at least there it's a pull through and relatively easy to use. All part of the learning curve.
I'm not planning on any major road trips, but even visiting the kids/grandkids will involve one or two DCFC stops, whenever I have time to visit them.
Did a deep dive here on the forums this weekend, y'all are going to cost me a lot of $ down the road. Found several mods that look interesting, and I'm considering a couple of my own ideas, my own take on an idea so to speak.
found this on my FB feed, throwback to my Cmax Energi back in 2017 the Brake coach is an old friend.
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_7055
The snow crust up here holds my 150lbs easily, loads of fun clearing the snow plow icebergs in front of my driveway, chopping it with a shovel all the way! Too much for my little snowblower, could not even scratch the surface.
Hope I don't have to go out anyway, we stocked up on food when we heard snow and ice was coming. But at our age, ya never know.
I charged up the truck to 95% the night before so I could use it as a power outage backup, but no power outage happened, so I have been using it during peak cost times and finally got it back down to 80% my preferred sweet spot.
Have fun customizing!
Ned B
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
Thanks! I’m down to a phone holder, and tonneau, both are on their way.
Following that I might do a tint on the windows, a dashcam, not sure what else it needs.
Maybe some mild all terrain rubber? Snowmaggedon aside, Virginia normally doesn’t get much weather that concerns me, and I’m loathe to reduce range too much.
  • Haha
Reactions: chl
yes, the snowmaggedon's are becoming more common lately....but I found the truck does well in the ice and snow with out snow tires around here anyway - Alaska, Canada, etc, snow tires would be a must I imagine.
Ned B
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
Busy week , had Storm in for 10k checkup, and I have been attacking the Snowcrete in the drive way with a spud bar. Strangely satisfying to chop with the 6’ bar and break up the snow. I’m getting my tonneau cover later today!
I’m doing a photo a day for a year project, and the lighting caught my eye on my way to work.
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_7128
Ford F-150 Lightning Found my 'Avalanche' XLT;  Storm IMG_7117
Reactions: chl
