Help dead won’t start at a customers home
PreservedSwine
Fort Myers
2023 Lightning
Hello, I stopped at a customers house- here maybe 20 minutes.
Turned off truck upon arrival.
20 minutes later attempted to start truck, greeted with steering trailer brake error, stop safely, parking brake error, frunk open, etc. and can’t start.
12v battery?
Can I just try jumping this thing?
Thanks
EDIT:
Now that I’m paying attention, when I press the brake pedal (truck off) has the little green light on the start/stop button always started bright- then flickers much dimmer? Is that a sign of a low 12v battery?
I have also noticed the starting chime recently began coming through the dash- as opposed to the sound system. Is that also a sign of a 12v that’s going bad?
Thanks
TheBigBezo
Earth
F-150 Lightning Lariat ER
I would check that the 12V is connected correctly. From others experiences here, if the 12V gets loose you get pandoras box of weird faults related to iffy power.
Gimme_my_MME
EDIT:
Thanks
Those are all signs of low 12v. Get a boost to get the truck started
PreservedSwine
Fort Myers
2023 Lightning
Thank you gentlemen.
Ford roadside assistance came, hooked up the battery, tender, it took about a minute, but it started.
Looks like I need a new battery
Ragman
2023 Lightnings - SR XLT, ER XLT, ER Lariat - 2024
Welcome to the 12V club lol - it takes very little to kick the truck into running - makes spending $50 on a cheap Lithium booster in the glove box worthwhile.
F150Flash
Keith
Goodyear AZ
F150 Lightning 2023
Retired accountant
I read a lot of posts about issues with the 12v battery. Since these have been in use for a few years (like forever) why are they such a problem in Ford EV's? Fortunately, I have not experienced a problem, but am perplexed by the issues they seem to cause.
mrau
23 Lariat⚡ER
One reason is the battery is smaller than a gas F150. The EV battery does not have/need the cranking amps (to turn over an engine) that a gas engine does. However, it does seem that the Lightning 12v battery does not always get charged properly from the High Voltage battery pack. Hopefully Ford can get that all worked out soon.
That said, I have not had any 12v problems either.
republicoftexas1836
J
2023 AMB Lariat ER, 2025 Mazda CX70 PHEV
Any recs?
Link?
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
12v battery?
Thanks
EDIT:
Thanks
I think I’ve heard other people describe those symptoms with a 12 V battery failure. Pretty sure I have read this somewhere on this forum
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
Exactly, I’ve always understood that a lithium battery lasted a lot longer than a wet battery
