Increase Ground Clearance
jobofly79
Joe
2024 Ford Lightning Flash 312A
I see a lot of people install leveling kits however those do not increase the actually ground clearance. I haven’t found any actual lifts for this truck. Has anyone increased the ground clearance and if so what did you use?
jobofly79
jobofly79
Joe
Tons of lift/level/tire threads.
True clearance is only gained by increasing the tire diameter.
I know about tires and levels. I’m asking about lifts. Not a lot about that.
Andrewbens
Modesto
Lightning
Mechanic
Eibach springs and shocks 3” for about $1,200s is the best kit currently and largest lift we have seen so far. There’s also a rough country 3” for $600.
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
are you though? Your original post asked about ground clearance. Since the lowest suspension components and electric motors are going to still be ~9” off the ground even if you lift it 6”, Helian’s earlier response is absolutely correct. The only way to increase ground clearance is to have larger tires (larger diameter).
Andrewbens
Modesto
Lightning
Mechanic
Yep he needs a 3” lift and some 35” tires
MountainAlive
Massachusetts, USA
Maybe this is about what Rivian does with its automatic suspension settings? It goes from about 8in of ground clearance to over 14in of ground clearance in all terrain mode.
21st Century Truck
Martin
So does my son's 2020 Audi Etron. It has an air suspension though.
Jodokk
Me
NC
22 Lightning Lariat ER, Agate Bl., Max Tow & AT tires. UnderCover Abyss Tonneau
College Professor
I want to hear more about Bluecruise performance after lifting. Has anyone had experience with the automated driving features after lifts?
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
I am confused about this. Isn't the motor bolted to the frame, and if you lift the frame 2" in the front, will not the motor lift 2" as well? As for the suspension components I agree, they are stuck to the wheel assembly and only bigger wheels will lift them.
WaterboyNorCal
Erik
NorCal
Nunya business ;)
Yes - you are correct. I misspoke when I mentioned the motors. They should be lifted by a "lift kit", but since the suspension components are fixed, then you have really only gained some clearance in the middle of the truck. Which is not insignificant, for mild off-roading. But as you pointed out, to change the OVERALL ground clearance (as would be needed for serious off-roading, rather than just wanting the "look" of a lifted truck), you would need bigger tires.
AZT9
Peoria, AZ
Truck has been leveled on on 34” tires since 2022. 84k miles and a lot of that with Bluecruise and ZERO issues 🤙🏼
Similar threads
