Is ForScan Mac / OSX compatible?
jackdeaoux
Jack
Walnut Creek CA
24 Lightning Flash iconic silver, 2024 moto guzzi Stelvio, 2023 EQE 350+
Is ForScan Mac compatible? I saw an obd2 scanner that is IOS compatible but is that the same thing?
potato
BC, Canada
2023 F150 Lightning XLT ER
No it is Windows software. It might run OK on an Intel Mac running Windows, but can't confirm that personally. I bought a cheap Windows laptop to run it.
iOS OBD dongles are a whole different story. iOS compatible there means Bluetooth Low Energy (BLE) as opposed to the original higher powered Bluetooth or WiFi. iPhones don't support non-BLE devices with custom profiles, only a few standard ones like audio devices.
jackdeaoux
jackdeaoux
Jack
Walnut Creek CA
Thanks
Yellow Buddy
Mid-Atlantic
Smart Ass
The Bluetooth OBD will not work with ForScan on a Mac. It’ll work on a ForScan Lite app on an Apple device, this will allow you to read but not program.
To use ForScan on a Mac, you need an intel based Mac and load Windows via Bootcamp. If you do that, you will be able to use ForScan when using the right adapter (Obdlink EX)
SpaceEVDriver
Arizona
Confirmed. This is how I run both Forscan and FDRS, with a Mongoose.
vagabond7846
NJ
FWIW I have tried to get this working via emulation (via UTM - instead of virtualization, since newer macs are not Intel based). TLDR its not worth the effort. I ended up buying a $199 windows laptop on amazon and using this for windows required software
ktn
MN
2023 F-150 Lightning® LARIAT ER
Works fine for me. I wrote a guide here: https://www.f150lightningforum.com/...allels-obdlink-mx-usb-bluetooth-dongle.21704/
