Lariat SR & Ford In-Dash Brake Controller
Dan
Haymarket, VA
Network Engineer
Hello, Lightnings!
My name's Dan, new '22 Lightning Lariat SR owner as of about 4 weeks ago.
My Lightning came with only the following options:
EQUIPMENT GROUP 510A
LINER-TRAY STYLE-W/CARPET MAT
FORD CO-PILOT360 ACTIVE 2.0
BEDLINER-TOUGHBED SPRAYIN*ACCY
No tow package to speak of (Lariat included?), but the truck has the 4 / 7-pin hookup in the back and the Class 4 hitch. But it does not have the brake controller in the dash- I have the coin slot.
In the driver's side door pocket was a trailer brake pigtail, part # FL3T-14A348-AA with 4 pin-outs. "No problem," I thought to myself- "A $27 Curt brake controller, solder & heat shrink it up, go under the dash, and plug it in. Easy, right?" Wrong.
Ford F-150 Lightning Lariat SR & Ford In-Dash Brake Controller thumbnail_323701952_831007534647147_4273302615878592502_n
I pulled the column cover off, went up there to find the pigtail connector, and nothing.
But I pulled the coin slot and found the 4-pin in-dash controller hookup:
Ford F-150 Lightning Lariat SR & Ford In-Dash Brake Controller 20230104_182504
Here's where things get weird. I said "Ok, fine- I'll get the Ford In-Dash Brake Controller, like this one from the Fairway Ebay Store":
https://www.ebay.com/itm/185661533380
Except it comes with the brake controller module. But it seems I already have it:
Ford F-150 Lightning Lariat SR & Ford In-Dash Brake Controller 20230104_181930
The Fairway Parts guy insists I need the full kit in order to enable the brake controller. I say, because I already have the module, I just need the switch.
Any insight would be helpful here. If I have to modify the code via ForScan to enable the controller it appears I already have, I will. I just don't see the point in replacing a perfectly good module unless I have to.
Thanks!
Bmann
Braden
2022 lightning
I did the same thing. I have a XLT ER with Max Tow, but without the tow technology package. I bought a ford in dash trailer brake controller from an ICE truck from ebay. I compared the part number on my under dash module to someone else’s XLT truck with a Tow Tech package and the part number is the same. I bought a Forscan connector and I’m starting it research what settings I need to change.
Dan_G_Lightning
Dan
Haymarket, VA
Network Engineer
You bought the controller box, the in-dash switch, or both from an ICE F-150? I see the in-dash switches on Ebay for $130+, and figured if I'm already out that much, I'd better just get the "official" kit including the control module from Ford for maximum chance everything just "works". Wishful thinking.
If I end up having to FORScan it, I will. It's just a computer with wheels.
mattb
Matt
CO
2023 F150 Lightning XLT
i'd love to hear about it when you get it to work!
dovetaildan
2022 F150 Lightning
mattb
Matt
CO
i just got this note from my dealer. seems like a lot if the parts kit is around $200.
I checked with our parts department, and it does look like we can order you the trailer brake control kit. It is $613.50+tax installed.
Dan_G_Lightning
Dan
Haymarket, VA
Network Engineer
The "official" kit is part number ML3Z-19H332-AB and the price should be $239.60 actual. Your price may vary from your parts supplier.
The installation is literally 10 minutes- The switch in the dash is a plug and click, and the module is two connectors and two 8mm bolts. I don't believe that anyone with basic tools and a picture guide (thanks dovetaildan) can't accomplish. I have a problem with paying someone the balance of your number to R&R two bolts and three clips.
The remaining unknown is the necessity of the FORScan or dealer tool to "enable" the new TCM and switch on a truck whose ASBUILT does not include it. Ideally, the new TCM would "advertise" itself as able to control the brake controller, and the other modules would just let it. This may be the reason for the high dealer price- Enablement with the other modules.
My controller part number above is still on backorder. I have not yet received it to attempt.
Given that ICE F-150s require the dealer or FORScan to enable it, why would the Lightning be different?
Blochead21
PA
Black 22 XLT 311pkg
Any knowledge on how to add in pro trailer backup if it wasn’t included on the as built?
mattb
Matt
CO
thanks for the update.
Gabe
Blainville
F-150 Lightning 2022 XLT ER
Hi, I have a XLT ER w Max Tow pakage. I was very disapointed when I discovered that the brake controller was not included with Tow pkg. I ordered one via my dealership but the device is BO for looooooooog. So we (my dealership!) tried to order a controler a generation before... They look the same. They got it installed but it doesn't work... They got in touch with a ford engineer that replied that it wasn't possible - for now - to get a brake controller installed on my truck... which s*ck.
mattb
Matt
CO
hi. has anyone gotten this to work yet?
Dan_G_Lightning
Dan
Haymarket, VA
Network Engineer
I am STILL waiting on the brake controller kit from Ford. They are still backordered everywhere (can't even find them on Ebay at this point). Expected to arrive later this week or early next.
I will update with everything I do to make this work.
