Platinum Dash & shifter modification inquiry
hoovertac
Brad
Tacoma Washington
AWD MME Extended Range
Crisis Counselor
I’m thinking of replacing my Platinum oversized display with a base model dash & shifter to a MME style knob. Does anyone know who in PNW can do this?
MidAtlanticLightningClub
F-150 Lightning Lariat ER
Lots of threads here on the shifter mod.
The problem with changing the display is the 15.5" portrait runs on Sync 4A, the 12" landscape on Sync 4. The numbers really a misnomer, though. Sync 4 is an updated Sync 3 whereas Sync 4A is an entirely different system. I would be afraid you would lose access to lots of the Platinum's features as they may not be included in the Sync 4 build set.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I'm sure you can find someone local that would want to do this mod/swap. Should be easily doable, but you'll need someone good at FORScan and FDRS.
