"Winding Down" sound when going slow.
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
Hi all
Just got my truck yesterday and love it!
1 question off the right away though. I wasnt expecting the sound of a "winding down" when slowing to a stop. Im using 2P drive as only had it for like 15 hours...
Its not bad but definitely noticeable and Ive not seen it mentioned before. Acceleration is dead quiet as is reverse. Just slowing just before stopping like at a stop sign or parking.
Thanks for listening!
swajames
CA
You’ll come to appreciate that sound. It’s regen charging your battery.
It's part of the pedestrian warning drone, it "winds up" when you start from a stop and back "down" when you come to a stop. As far as I can tell it tapers down above 15 and pretty much goes away above 20. At that point there's sufficient road noise. Honestly though, it's superfluous when it's hot outside and the A/C is running. The compressor is as loud as an ICE idling.
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
Perfect thanks for the response I appreciate it.
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
My truck is going into dealership Oct 16 for the CSP 23B57, and they asked if I have any other concerns..
I have deleted the pedestrian warning sound speaker (temporarily), as I still believe my truck has a noisy acceleration and deceleration characteristic..
As mentioned it sits right between 15km and 20km (9mph and 12mph) on acceleration/deceleration, and its loud inside the cab, and can be heard inside out house! My neighbors have said we can hear when you get home as it permeates through walls, and truthfully wakes up our ?.. It seems to be coming more from the back motor.
Happens exact same when using 1PD or not, and in all drive modes.
Stop and go traffic is a bit of a drag with it.
I cant believe this sound is normal...
Attaching video clips (hopefully)..Does your truck sound like this?
TheBigBezo
Earth
F-150 Lightning Lariat ER
Yah, I don't think it's any sort of purposeful noise. It's just the sound of beefy engines. The motors in our trucks are a bit over engineered. I personally enjoy the sound, it's quasi scifi. I don't think there's any way to mask it, if you drop the hammer in a Tesla you'll hear motor whine too just not quite as loud, because again, our motors are beefy.
Edit: I also don't think it's necessarily regen either. Our motors spin at very high rpm so I think we simply can't hear it the upper bands but at low rpms when it's spooling that's when it becomes audible. That's my guess, at least.
PA Lightning
Tbone
PA
Lightning Pro
Never heard a lightning make that sound. Sounds like the Jetsons' model.
I am sure your dealer should be able to identify the problem
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
Right?! I also had a Lightning approach me at Home Depot recently just to say Hi, and his definitely arrived and departed much quieter!
VictorM
Victor
Western PA
F150 Lightning XLT ER
Experiential Knowledge Griot
Hi all
Same here. didnt expect it to be that loud
strmwzrd
Nebo, NC
Hi all
Drop it into 1P and you'll hear feel even more of the regenerating effect.
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
The sound is the same whenever the speed is within that range, regardless of 1PD or 2. We use 2PD typically in Sport mode. Makes no difference what mode or drive you're using.
I think its an issue, but dealer should be able to confirm/compare to other F150 Ls on lot.
strmwzrd
Nebo, NC
I responded before I saw the video. I thought you were hearing "normal" regenerating sounds. Your's may be possessed...
TheBigBezo
Earth
Same here, mine for sure winds down but not like that. That's interesting though, let us know what the dealership says.
bub
F150 Lightning Plat
Mine makes these noises as well. Not sure its as loud as yours. Seems to only be present at low speeds. I just assume its normal operation of the electric motors.
I'm in Canada and it reminds me of the sounds you hear on the Vancouver Skytrain.
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
Im on Vancouver Island! My family said this exact thing when we were on Skytrain a few weeks ago to see Sting! "Sounds like the truck!"
  • Haha
Reactions: bub
