Rear lowering shackles - prior gen fit 2021?
graywhiteboy
Jeff
Seal Beach, CA
2021 F-150 Supercrew 2wd 5.0
Woodshop Teacher
Do you know what your measurements were prior to the install? I’m thinking of doing this and raising front an inch to make level- also have a 2wd stx but I have the 18” wheels and sits super low in front- going to be changing to 20” fuel wheels- want the leveled off-road look without killing mpg and keep it easy to get in and out of.
The photos show the before and after measurements.
nubbles
Josh
Houston, TX
2021 F150 RCSB 5.0
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
Hi! Anyone know if the rear lowering shackles from the previous gen (2015-2020) fit the 2021s? Thanks!
According to what I understand the 2021s are different. My friend tried a set for a 2020 and they wouldnt fit. I had a 2020 f150 FX4 anddid remove the block under the spring and it had absolutley no affect on drivetrain geometry.The 2wd 2015-2020 did not have the block. On my 2020 FX4 it lowered it the exact height of the block. I didnt even have to get shorter bolts.The oem bolts were threaded enough.The 2021 F150 FX4 that I got yesterday hjas what they call a mono-leaf system on the rear were the 2015-2020s had a multi leaf setup. The block on the rear of my 2021 FX4 appears to only 1 1/2" where my 2020 had a 2" block. With just a 1 1/2" drop. If you remove this block you should get an actual 1 1/2 drop without any complication or shimming. I plan to remove mine tommorrow and the oem U bolts also appear to be threaded enough to make uop the difference.The F150s WITH the towing package, have a stiffer mono-leaf spring as opposed to standard spring giving it more arch therefore a higher lift in the rear
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
anything more than 3 inches up or down requires shimming of Diff
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
I removed the 1.5" blocks on my 2021 FX4 today lowered exactly 1.5" on the rear and it actually raised the front about 3/4".I had plent of threads on my existing u-bolts. it worked out really well. there is also a company that I found that makes the 2" lowering shackles for a 2021 and 2022 F150. MAX TRAX Suspension store. they are $93.75 per pair and readily available
RedundanT
GB SA3 4EN
2021 RCSB 5.0
Making lego parts for new vehicles
I used ebay Crown 2" shackles and they fit fine, with trimming of the bed support for clearance. Left the blocks in mine till I get some 2.5 degree shims since the block appears to be tapered.
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
i have some shims as well gonna put then in tomm
Efrommel
Erwin
Puerto Rico
F150 XLT
Videographer
Are the ford performance available for the 2021? or are the same for the 2020?
cashton
Randy
Omaha, NE
2021 Ford F150 XLT
HSV_MIkeJ
Huntsville, AL
www.music-by-mike.com
2021 Ford F-150 Lariat, SC Rapid Red
DJ
From looking at my 2021 and from what I have read, using the 2" drop shackles on a 2021/22 would require cutting into the bed support brace, since the leaf spring would hit it.
Ford F-150 Lightning Rear lowering shackles - prior gen fit 2021? IMG_7558
RedundanT
GB SA3 4EN
2021 RCSB 5.0
Had to trim a little for my Crown 2" nit that bug of a deal.
